RCCB as main switch? | Page 3 | on ElectriciansForums
Discuss RCCB as main switch? in the UK Electrical Forum area at ElectriciansForums.net
N
Noob2013
Hi all,
I have been to a property where the tails come out of the meter and into an RCCB which then feeds the main switch of the consumer unit. All circuits are protected by MCBs.
If I'm adding a new circuit, is it best put in an RCBO instead of an MCB?
Yes Noob you should not have 2 of the same mA RCDs in line, unless your RCCB is 100mA & time delayed.
As you have not given a mA for the RCCB which would normally be on the front, are you mistaking it for a ELCB?
You may need to take a pic of it so members can check.
Reply to RCCB as main switch? in the UK Electrical Forum area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
Also use a tails gland and clamp if available and make sure tails are secured to a wall. The danger here is a live to earth fault in the Consumer Unit
