View the thread, titled "RCD Earth Leakage" which is posted in UK Electrical Forum on Electricians Forums.
G
garysparky1
I Need a little help i recently fitted a new consumer unit for a mate. The house is empty and up for sale so i thought no problem as not in a hurry continuity was ok on all circuits IR ok ,Ze 0.09,PFC 2.95kA so i changed the board then powered up and the 80a 30Ma RCD tripped i disconnected each circuit and reset it tripped on each circuit. I've since gone back with a clamp meter and found 29-39Ma running through the bonding. I clamped ( on lowest setting)the neutral and line seperately on each circuit and got kitchen N-0.70 L-0.46Ma and downstairs lights N-0.47 L 0.10 surely these differences in reads are too high can anybody steer me in the right direction. :frown2:
hmm... i would really like to know the end result to this.. If it were a N-E fault. Provided it doesnt enter into an ego slanging match.. Coz lets face it Electrical Trainee or not were all in it together regardless of experience...
I agree with everything you say nick, trouble is i still don't know if anything i said was wrong.
Be interested in any of you other guys opinion.
well, jason says you ain't going to be banned ( yet) , and i can't see the council taking your dustbins away in this weather, so you's OK.
GetInline.aspx
Either I‘m going mad or senile. I thought a single RCD was compliant under the 16[SUP]th[/SUP]. Correct me if I’m wrong!
There was a N bar for the main switch side and one for the RCD side on a standard split load db...so it was still possible to cock up the neutrals back in the 16th days!
Reply to the thread, titled "RCD Earth Leakage" which is posted in UK Electrical Forum on Electricians Forums.
