Rcd main switch | on ElectriciansForums
Discuss Rcd main switch in the UK Electrical Forum area at ElectriciansForums.net
Tim
ESSEX
Hi guys,
I admit this is just me being to lazy to go to the van and get my regs book.
The reg about not using an rcd as a main switch, does it specify a ma rating or anything about time delayed or TT system exemptions?
I ask as i was planning to replace a main switch with a 100ma type s rcd (TT system) but that reg just popped into my head. Space is limited so i would rather not have a seperate enclosure if it can be helped.
I cant see any difference in having it in the cu or in its own enclosure other than the RCD switch isnt big and red like a main switch.
Cheers,
Tim
Reply to Rcd main switch in the UK Electrical Forum area at ElectriciansForums.net
Also use a tails gland and clamp if available and make sure tails are secured to a wall. The danger here is a live to earth fault in the Consumer Unit
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
