rcd requirement | on ElectriciansForums
Discuss rcd requirement in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
manjit
london
Hello just wanted to ask, my friend has done an extention, and new wiring, with new lighting, ring main, my friend has all rcbos in CU, and he has run the wiring, and contected to rcbos, but he has been told that the new wiring, i.e that the extention wiring should be rcd protercted, it dosent matter if each of the circuit is protected with rcbos,
i.e the lighting circuit is protected by rcbo and so is the ring mains and the cooker, does it still need rcd protection.
Any help would be really apprecitaed.
thank you
Thank you for your reply, he was told by a professional electrican as he wants it certified, Sorry he has got some knowledge of electrics , as he used be an electrican , but has been out of the game for few years now.
The qulified electrican who is going to give him the ceritification told him that he needs RCD, protection , with rcbos.
@manjit Your friend needs to ensure compliance with Part P of the Building Regulations, paying particular attention to requirements to notify Building Control.
Think of an RCBO as a combined MCB (providing overload protection) and an RCD (providing earth leakage protection) but in a single device.
Well your friend is OK then - the system has RCD protection.
#1 and #4 are at odds with each other. Has this electrician actually seen the consumer unit.
I may be being sceptical here, but is it you that is actually doing the work, rather than a friend?
Well this Electrician who is going to certify the installation ought to throw his tools away cus he doesn't know what he is talking about
Thank you all of you for your help, really appreciate it, no it's not me doing the work, sorry to say.
Yes I can attach pictures of the CU, that have been send to me.
[ElectriciansForums.net] rcd requirement [ElectriciansForums.net] rcd requirement [ElectriciansForums.net] rcd requirement
Top job, all circuits bar one have rcd protection by way of rcbos.
[automerge]1571837440[/automerge]
What is circuit 13 identified as.
Status
Reply to rcd requirement in the UK Electrical Forum area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
