E
eco-tech
The job im about to do is a extension and im going to extend the ring main and the lighting radial etc.
The client does not want me to chase his walls to the 50mm that regs states and he will not pay for a CU change and a full part P test as his board is not a split RCD Cu.
So i would like to know if i can use RCD Sockets on the ring main in the extension and bury the lighting cable in conduit to meet regs etc ?
Please Advise if i can do this ?
This way i can issue a Minor-Works Cert !
