RCD Tripping - Advice Needed | Page 3 | on ElectriciansForums
Discuss RCD Tripping - Advice Needed in the UK Electrical Forum area at ElectriciansForums.net
London
Hi Everyone,
So basically like a few other people, I really need some advice from some professional electricians and found this forum so I really hope someone out there can help.
Basically we had a hot tub installed back in June 2017, everything was running fine, till we went for a holiday in December 2017 so turned it off. When we came back, filled it back up and turned in on. Ever since that month 2 weeks after, our RCD seems to be tripping every now and again very randomly.
We called in a electrician who stated "I told you your old consumer unit may not supply enough power and it's given up". At that point, other devices in the home like our speakers were tripping the RCD instantly but yet at the neighbours house when tested, didn't.
So we went ahead with his advice of changing the whole consumer unit (he said it was worthwhile as the new 17th Regs came out and wouldn't hurt as it was 10 years old+)
So now once he fitted the new consumer unit, turned everything back on.. and voila all sorted. However, a week later, the new consumer unit RCD is tripping again! We tried to do our own fault finding and found that turning of the hot tub stopped the tripping. Called him and he said he doubts its the hot tub, so we called him out to come and see. In front of me, he showed and said the hot tub is fine, and is showing the correct voltage/amps at the tub. He said the next step is to do fault finding but its going to be running into the hundreds ÂŁÂŁÂŁ and said the next time it happens try and unplug everything and plug one by one in to see if we can work out what's causing the RCD to trip, otherwise he's going to have to come and rampage through all the devices/sockets and made out it's a massive job.
So he left, and long and behold it tripped later on, so I did what he recommended, unplugged all our plugs from the sockets, and plugged them one by one..RCD didn't trip.
So having all circuits on again, the RCD seems to be tripping again and again daily. For example a 2 days ago, it tripped twice, just yesterday it tripped four times.
I still have a serious hunch its the hot tub, so yesterday night, turned it off at the consumer unit, and touch wood, it hasn't tripped up to now.
My question is to the electricians out there, is the hot tub causing the RCD to trip? The electrician said it's not the hot tub, yet when I turn the circuit off to the hot tub it hasn't tripped the RCD (as of yet).
I was also doing a bit of research about this earth leakage topic, and I'm not sure if I'm right, but am I right in thinking that if there is enough earth leakage on all the circuits it would trip the RCD? Reason being is that if I go with the theory its the hot tub, I'm guessing when the blowers automatically come on, or the pump/heater comes on, it's possibly sending a spike over the RCD limit?
The reason I came up with this theory is that we do run a small business from home, we have about 3 pc's, 8 monitors, 2 big laser printers, two freezers, three fridges..etc do you think that the earth leakage of all these are adding up, and the hot tub is the cherry on the top that's causing the it to trip randomly?
Just as background information, he's put a single RCD that's connected to our Kitchen Sockets, Upstairs Sockets, Downstairs Sockets, Shower, Utility Room Sockets and the hot tub. He has then used RCBO's on each lighting circuit.
Any help would be gratefully appreciated.
Kind Regards,
Jake
I already feel sick as it is @ipf, if I give out the figure I think i'm just going to faint, could you tell me what an average charge would be to change this to this new one?
Presuming it was just to change the consumer unit, with the RCBO's, 450-500 ish, I would imagine. Depends exactly what he did.
That is Wylex ........... so the bill was probably closer to ÂŁ625
Maybe. Top of my head and presuming no probs.
Thanks @camerabloke, I'll get back to you soon.
Honestly the community here is 100% strong, I had posted on another forum, and they were telling me that it's one of my speakers were faulty...honestly goes to show that some electricians like yourselves know what your doing and some don't have a clue. I'm definitely not giving him any more money, however, I can breathe a bit knowing that I hopefully wasn't completely ripped off...It was ÂŁ600.
Do you know how much more it would be to fix this in my position?, I appreciate your offers to come and help, but honestly need to keep some money aside to fix this mess.
That is almost impossible to say.
My thoughts are site visit to use my earth leakage clamp meter and almost certainly swap the hot tub on to a RCBO
Why the lights are on a MCB needs investigation - and hence why what the "spark" wrote on the certificate may be enlightening...
I'd suggest no hot tubbing for a while, then...;)
Ok thanks for all your replies.
@Murdoch I'll have a look at the paperwork tomorrow, all I remember however is them saying something about our house wiring was tripping because of a "shared neutral" ? I'm not sure if that's the reason the MCB is there.
If that's the case, it should have been sorted out with the job...they've just left it open to further problems. That mcb indicates.
@ipf @camerabloke
Honestly, I've just developed a really bad migraine, I feel completely gutted inside.. especially if they should have fixed the issue. I honestly never thought this would happen to us personally, see it on tv and video's but I hope this isn't going to cost me an arm and a leg to fix.
Thanks for your replies...I'm definitely not using that hot tub till this is checked over :eek: I hope there isn't more of a nightmare inside the consumer unit
Reply to RCD Tripping - Advice Needed in the UK Electrical Forum area at ElectriciansForums.net
Which rcd is it? Is it one for everything, one for a few circuits?
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
