RCD trips a few minutes after lights turned on | Page 4 | on ElectriciansForums
Discuss RCD trips a few minutes after lights turned on in the UK Electrical Forum area at ElectriciansForums.net
H
harpoon
Hi all,
I am trying to diagnose the following problem.
After coming back from holiday, we noticed that our RCD keeps tripping a few minutes after our kitchen lights have been turned on. If the kitchen lights are kept switched off, then everything is ok.
The lights were GU10 spotlights connected to a dimmer switch. Replaced the dimmer switch with a trailing edge dimmer and replaced the GU10 with dimmable LEDs ... and the problem is still present.
Any ideas what this could be and how to test the fault ?
Could there be water somewhere in the ceiling cavity ?
Any advice is appreciated !
Many thanks !
Harpoon
We opened up the switch box and eventually the electrician determined that it was not the N-E short. The N-E fault was a false alarm probably triggered by the RCD (not sure about that) ?
The L-E fault was still resistive, low enough to trigger the RCD, but high enough not to draw too much current.
Goes to show that electricians and builders have different mindsets ... I guess the builder was over-keen to put insulation in the ceiling ... and just overdid it. The electrician on the other hand did anticipate this and created enough space around the lights.
In any case, I'll be switching to LEDs from now on ... less heat and power dissipation !
The N-E 'fault' is most likely the N-E loop of a TN-C-S installation. If you're not an electrician, with TN-C-S you have a line conductor and a neutral conductor coming in to the service head. The earth is then linked to the neutral conductor. TN-C-S stands for Terra Neutral Combined Separate as in earth/neutral combined (in the cable) and then separate (at the service head).
On the consumer side, if the installation is not fully isolated you will get a continuity reading between earth and neutral which is why you should fully isolate circuits for this kind of fault finding.
Thanks SparkyChick ... I drew the line when I have to open up my consumer unit.
Maybe later in the year (can't believe June is coming to an end !) I will enroll in a course and get qualified as an electrician to better protect my house !
btw, I had the electrician test my RCD again to make sure it is all working and it is.
agreed ... but it is a start. I am already competent in most things electrical/electronic ... but do not know much about a household (or industrial) installation as well as all the tests that are typically performed. Saw my electrician's Kewtech KT65DL and I was already drooling ... =)
Will happen on TN-S also as neutral and earth connected at the star point of the transformer :)
Maybe later in the year (can't believe June is coming to an end !) I will enroll in a course ,perhaps in November,and by Christmas I'll officially be qualified as an electrician to better protect my house !
Corrected that for you to be more realistic with current training requirements.
Reply to RCD trips a few minutes after lights turned on in the UK Electrical Forum area at ElectriciansForums.net
Have you notified Building Control of these works?
