In this case the RCD is purely there as a DP switch as we haven't been able to get a non RCD board.
Screwfix have a Crabtree main switch unit stock no. 77250 which is what I used, it gives a spare non-RCD way for the freezer into the bargain.
Thank you for your view on this matter, i will be contacting megger to see if they can shed some light on how my megger works!
Can anyone see a problem with fitting a 30mA RCBO on the PV circuit (providing inverter can work with 30mA RCD) - thus you would have the main RCD protecting circuits from the mains supply and RCBO protecting other circuits from the PV system. I can't think of any reason why this wouldn't work.
Reply to the thread, titled "RCD's with Photovoltaic's?" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
