Chapter 52.
Selection and Erection of Wiring Systems .
526. Electrical Connections’ .
:icon_bs:
526.6. There shall be no appreciable mechanical strain on the connections of conductors.
526.7. Where a connection is made in an enclosure the ((enclosure shall)) provide adequate mechanical protection and protection against relevant External influences
long way for a short-cut.
External influences are all over the regulations. (know your IP codes )
learning curve only . 702.414.4. Requirements for SELV and PELV circuits.
702.414.4.5. Where SELV is used, whatever the nominal voltage, basic protection shall be provided by :
416.1 - Basic insulation ; or
Barriers or enclosures and affording a degree of protection of at least IPXXB or IP2X. Complying with 416.2.
:icon_bs:
Only be treated as an aide-mémoire to the Regulations and Electricians should always consult BS-7671:2015: to satisfy compliance.
Learning curve only.
:icon_bs:
702.55.4. Special requirements for the installation of electrical equipment . etc refer ........................................
Fixed equipment designed for use in swimming pools and other basins ( e.g. filtration system, jet steam pumps ) and supplied at low-voltage is permitted in zone 1 , subject to all the following requirements being met:
- The equipment shall be located inside an insulating enclosure providing at least Class II or equivalent insulation and providing protection against mechanical impact of medium severity ( AG2)
P /406 ( Code > AG - External influences : Mechanical stress impact ) & ( External influences : AG2 - Medium severity )
Leaning cure only . ( Where do I use the IP Codes )
P/216 . Fig - 702.1. Zone dimensions for swimming pools and paddling pools .
:icon_bs:
Equipment selected for Zone 2 would need to be manufactured to an IP rating of IPX2 (drip proof) for indoor locations, IPX4 (splashproof) for outdoor locations or, where water jets are likely, IPX5 (jet proof). Again, the manufacturers’ guidance on installation and suitability should be followed.
:book: Zone 0 – the interior of the swimming pool basin
Zone 1 – the area surrounding the edge of the pool for a distance of 2.0 m and a height of 2.5 m
Zone 2 – the area surrounding Zone 1 for a further distance of 1.5 m and a height of 2.5 m
NOTE it is important to remember that because the swimming pool is considered a special installation or location, due to the wet conditions, basic protection for any SELV circuit must have basic insulation or the conductors must be behind barriers and enclosures to at least IP2X.
Index of protection IP codes for general guidance.
Zone 0 :- Minimum degree of protection :- IPX8.
Zone 1 :- IPX4 or IPX5 for water jets likely to occur for cleaning purposes.
Zone 2 :- IPX2 for indoor locations, IPX4 for outdoor locations and IPX5 or water jets likely to occur for cleaning purposes .
The power or right to decide or act according to one's own judgment ...........
:aureola:
For zone 0, the protective measure against electric shock would need to be provided by SELV at a nominal voltage not exceeding 12V.
Equipment selected for the interior of the basin (Zone 0) would need to be manufactured to an IP code of IPX8.
For Zone 1, the protective measure against electric shock would need to be provided by SELV at a nominal voltage not exceeding 50V.
Equipment selected for Zone 1 would need to be manufactured to an IP code of IPX4 (splashproof) or where water jets are likely, IPX5 (jet proof)
BS:7671 allows a conventional BS 1363 socket outlet, providing it is non-metallic, to be installed at least 1.25 m from the edge of the pool and at least 0.3 m from the floor. The protective measure against electric shock for this socket outlet circuit would generally be automatic disconnection of supply with the additional protection of a 30mA RCD.
Lighting circuits in Zone 1 do not necessarily need the protective measure of SELV if they are installed on a wall within the zone’s dimensions providing that:
• The circuit protected by automatic disconnection of the supply and additional protection is provided by a 30mA RCD.
• The height from the floor to the luminaire is at least 2 m.
• The luminaire shall have an enclosure providing Class II or equivalent insulation.
• Protected against impact of medium severity (AG2).
• Automatic disconnection of the supply (which includes earthing and bonding) used in Zone 2 would require the additional protection of a 30mA RCD.
Supplementary equipotential bonding shall be provided, connecting all extraneous conductive parts and exposed conductive parts in Zones 0, 1 and 2 together. Where a metal grid is installed in a solid floor, it should be connected to the local supplementary bonding.
Wiring systems, surface wiring or otherwise, should preferably not employ metallic conduit, trunking or exposed metallic sheath.
Underwater lighting located behind portholes, and serviced from behind, must comply with the appropriate part of BS-EN-60598 and be installed in such a way that no intentional (or unintentional) conductive connection between any exposed conductive part of the underwater luminaires and any conductive parts of the portholes can occur
P/306. BS-EN-60598 Luminaires .
:book: :icon_bs:
BS-7671:2008:2011:2015:
Special installations or locations because of the increased risk of shock arising from the fact that a person’s body resistance is significantly reduced when wet and only partially clothed and by good contact with earth.
Locations require a higher degree of protection for equipment, which is likely to be subject to water splashes or sprays.
Special requirements not only apply to the swimming pool but also to the surrounding area.
Equipment selected for the interior of the basin (Zone 0) would need to be manufactured to an IP rating of IPX8, which means that the underwater lighting equipment would be able to withstand any water ingress when totally submerged with water under a pressure greater than 0.1 bar. The manufacturers’ guidance on installation and suitability should be followed, and you should also confirm that the underwater luminaire complies with BS-EN-60598-2-18.
P/306. BS-EN-60598-2-18:1994 + A1:2012. Luminaires.
Particular requirements, Luminaires for swimming pools and similar applications . 702.55.2. 702.55.3.
:icon_bs:
There are two sets of code’s to relate to (IP) wise.
1) International Protection (IP) Code’s ...... ◄
:uhoh2:
2) Ingress Protection. (British) BS-7671: ◄ P/405. IP codes.
:icon_bs:
416.2 Barriers or enclosures
Note: Barriers or enclosures are intended to prevent contact with live-parts.
A letter (B) is sometimes added after (XX) IPXXB the XX means that the first and second numbers are NOT specified . (B) Means finger protection is provided against any hazard in the Enclosure.
Electrical equipment (Enclosures) are specified in the form (IPXX?) As appropriate.
“ first ” and/or “second ” X is replaced by a number . IP2X. IP??2X )
416.2.1. Live parts shall be inside enclosures or behind barriers providing at least the degree of protection IPXXB or IP2X . Refer. Etc
416.2.4. (iii)
where an intermediate barrier providing a degree of protection of at least IPXXB or IP2X . prevents contact with live-parts, by the use of a key or tool to remove the intermediate barrier
Notes IP Codes .
First :
- Degree of protection is stated in form ((IPXX))
- Protection against contact or ingress of water respectively is specified by replacing first or second (X) by digit number tabled e.g. (IP2X) defines an (enclosure) giving protection against finger contact but without any specific protection against Ingress of water or Liquid .
This information should be used for general guidance only. Refer to BS-EN-60529. for full information.
Where the first or second numeral is not required to be specified, it is replaced by the letter (X)
:icon_bs:
What new to BS-7671:2015
INTERNATIONAL PROTECTION code. 412.2.2.3.
:uhoh2: :book:
BS-7671:2015.
P/41. - Abbreviations used in the Standard. (IP) International Protection Code . ◄◄◄
:30:
P/66. - 412.2.2.3. Where a lid or door in an insulating enclosure can be opened without the use of a tool or key, all conductive-parts which are accessible if the lid or door is open shall be behind an insulating barrier (providing a degree of protection not less than (IPXXB or IP2X) preventing persons from coming unintentionally into contact with those conductive-parts . This insulating barrier shall be removable only by the use of a tool or key.
P/234 - Section 709
Marinas and Similar Locations. :svengo:
IP characteristic numerals .
First -
a) Protection of persons against access to hazardous parts inside enclosure(s)
b) Protection of equipment against ingress of solid foreign objects.
Second - Protection of equipment against ingress of water.
No. Degree of protection
First - 0
(a) Not protected
(b) Not protected
Second - Not protected
First - 1
(a) Protection against access to hazardous parts with the back of the hand.,
(b) Protection against foreign solid objects of 50 mm diameter and greater.
Second - Protection against vertically falling water drops.
First - 2
(a) Protection against access to hazardous parts with finger
(b) Protection against solid foreign objects of 12.5 mm diameter and greater.
Second - Protection against vertically falling water drops when enclosure tilted up to 15° vertically falling water drops shall have no harmful effects when the enclosure is tilted at any angle up to 15° from the vertical.
First - 3
(a) Protection against contact by tools, wires or such like more than 2.5 mm thick.
(b) Protection against solid foreign objects of 2.5 mm diameter and greater.
Second - Protection against water spraying at an angle up to 60° on either side of the vertical.
First - 4
(a) As 3 above but against contact with a wire or strips more than 1.0 mm thick.
(b) Protection against solid foreign objects of 1.0 mm diameter and greater.
Second - Protection against water splashing from any direction.
First - 5
(a) As 4 above
(b) Dust-protected (dust may enter but not in amount sufficient to interfere with satisfactory operation or impair safety)
Second - Protection against water jets from any direction.
First - 6
(a) As 4 above.
(b) Dust-tight (no ingress of dust)
Second - Protection against powerful water jets from any direction.
First - No code.
Second - 7
Protection against the effects of temporary immersion in water. ingress of water in quantities causing harmful effects is not possible when enclosure is temporarily immersed in water under standardized conditions.
First - No code.
Second - 8
Protection against the effects of continuous immersion in water under conditions agreed with a (manufacture)
P/234 - Section 709
Risks at Marinas.
Degrees of protection provided by enclosures for electrical equipment against external mechanical impacts (IK code)
Code letters IK
(international mechanical protection)
:30:
Characteristic group numeral
(00 to 10) ... example. IK/05
Each Characteristic group numeral represents an impact energy value as Shown below.
IK Code: IK00, IK01, IK02, IK03, IK04, IK05, IK06, IK07, IK08, IK09, IK10.
Impact energy
IK00 - No protection specified
IK01 - 0.15.
IK02 - 0.2.
IK03 - 0.35.
IK04 - 0.5.
IK05 - 0.7.
IK06 - 1.
IK07 - 2.
IK08 - 5.
IK09 - 10.
IK10 - 20.
Where higher impact energy is required, the value of 50 joules is recommended.
Posted by request
Re-cap prior to the next edition:
Circuits Requiring Additional Protection (30mA RCD)
Regulation No. 411.3.3.
Notes:
All sockets up to 20A rating must be 30mA RCD protected unless labelled for a particular item of equipment. The provision for omission of RCD protection where there is a Risk Assessment does NOT apply to dwellings.
Notes:
All sockets up to 20A rating must be 30mA RCD protected unless labelled for a particular item of equipment. Or if there is a written risk assessment to say RCD protection is not required.
• Location: Mobile equipment outdoors with a rating of up to 32A
Notes:
Includes 3 phase supplies. No exceptions.
Regulation No. 701.411.3.3. 701.415.2.
Notes: (None)
• Location: Circuits passing through bathrooms Zones 1 and/or 2
Notes:
Only applies to Zones 1 and 2, not to cables outside the Zones.
• Location: Cables without mechanical protection at a depth of less than 50mm in a wall
Regulation No. 522.6.202. 522.6.204
Notes:
Cables should be in Safe Zones and 30mA RCD protected.
• Location: Cables in walls with internal metal construction unless protected
Regulation No. 522.6.203. 522.6.204
Notes: Unprotected cables such as twin and earth in metal studwork walls.
Regulation No. 702.410.3.4.2. 702.419.3.4.3. 702.53 702.55.1
Notes: Supplies to equipment in the Zones.
Regulation No. 703.411.3.3.
Notes: All circuits in the sauna.
Regulation No. 704.410.3.10
Notes: 230/400V Sockets up to 32A.
Regulation No. 705.411.1.
Notes: Sockets up to 32A.
Regulation No. 708.553.1.13.
Notes: All socket outlets. Each socket outlet to have individual RCD.
Regulation No. 721.411.
Notes: All circuits and must interrupt all live conductors.
Regulation No. 709.531.2.
Notes: Socket outlet. Device must disconnect all poles including the neutral. Sockets to be individually protected by an RCD.
Regulation No. 710.531.2.4. 710.411.4
Notes: Socket outlets and all circuits up to 63A in Group 1 locations.
Regulation No. 711.411.3.3.
Notes: All socket outlets. All circuits other than those supplying emergency lighting.
Regulation No. 712.411.3.2.1.2.
Notes: May be required for supply cable and RCD needs Type B.
Regulation No. 714.411.3.3.
Notes: Lighting in telephone kiosks, bus shelters, advertising panels and town plans.
Regulation No. 717.515.1
Notes: LV circuits supplying equipment outside the unit.
Regulation No. 722.531.2.101.
Notes: Every charging point to have individual RCD that disconnects all live conductors.
• Location: Temporary installations for structures, amusement devices, fairgrounds etc
Regulation No. 740.415.1.
Notes: All lighting circuits, sockets up to 32A and mobile equipment up to 32A.
Regulation No. 753.415.1.
Notes: Circuit supplying heating system.
Re-take - Useful Information for 2394 :
Electrical Course Trainees Only
amberleaf,
Richard Burns,
