Guest viewing is limited
Should have taken a step back and thought what is the best way to do this.
The supply company feeds a meter, then it goes to the 1st board which feeds 4 sub boards, there is a meter before each sub board. The 4 sub boards are protected by 63A 3 pole CB's.
The supply company feeds a meter, then it goes to the 1st board which feeds 4 sub boards, there is a meter before each sub board. The 4 sub boards are protected by 63A 3 pole CB's I said RCBO by mistake.
Usually, you would have an MCCB board with meters in the outgoing all in the landlord's cupboard.
Birmingham
Rear entry three phase board
Commercial Electrical Advice
Gigsy,
Gigsy,
