Recommendations for metal cable fixings | Page 2 | on ElectriciansForums
Discuss Recommendations for metal cable fixings in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
Somerset
I am planning a job in Bath for an EV Charger on a Grade 1 listed building.
Have a long cable run at height, planning dept have raised issues with cable cleats! feel they are a bit chunky and would prefer something with a less chunky profile!! given they are nearly 2 and half stories up from ground nobody is going to notice! but the planning guy is a pedantic so and so.
Have also stipulated that cable and fixings must be painted on completion to blend in with Bath stone.
Owing to the length of cable run I will be using H07RNF - lighter and easier to work with up the scaffolding than SWA. Customer doesn't mind cost.
Only low profile option I can think of is metal cable ties and bases. base screwed to wall then tie cable. paint on completion.
If I used metal buckle clips then they are a bit fiddly to work with on larger cables.
Any other suggestions?
Go back to the planning arsetrumpet and get them to tell you exactly what they want you to use, otherwise they're just going "no guv, you can't use them ugly clips and plain cable, you must paint the cable the colour of the clouds and it must be secured with pixie tears from a thousand ground up pixies, oh yea and don't forget to comply with 7671 but the pixie tears MUST be used....and we're not going to tell you where the pixies are!"....cue them girlishly sniggering and skipping off to see the sherbet king atop gumdrop mountain
Nah just get tiresome of half information, like when the wife says get me a drink so I get the drink and go to give it to her (placed in hand so you know, she can drink it) only to get "put it on the table then"....if that's what you wanted WHY DIDNT YOU BLOODY SAY SO! ?
ANYWAY divergence over ?
With practice, you can get it the other way round. :)
Reply to Recommendations for metal cable fixings in the UK Electrical Forum area at ElectriciansForums.net
