Can some please advise how to reduce a 10mm cable ferrule to 6mm ferrule size? I have an old CU where neutral terminal would not take such big ferrules. Im not worried about current capacity drop as circuit is fed from 30A MCB anyway. I will change it to 40A or 50A when I replace CU and install the correct ferrule then. Optionally, can I just remove some strands (not too many, just enough to fit into 6mm cable ferrule (its 10mm HO7RNF)?
