Guest viewing limit reached
Factories, mines, quarries, among others.
Having the necessary skill, knowledge or ability to do something successfully.
Sorry, you may believe everything is covered, but there really has been no change since Corgi was introduced.
The Regulations only apply to persons who conduct gas work for remuneration, and will continue to do so, until competent is changed to qualified.
You may well be able to be done for impersonation, but only if you tell someone that you are registered.
Quarries, mines, factories, training centres, caravans, boats and portable devices are not covered and you do not need to be competent to fit them or work on them.
Bizarly I have answered my question by arguing about the regs- Am I a competent electrician? Will the house sell without correct paperwork? Will anybody sign off my work- No!
Jase your living in a dream world..please fly back over to the plumbing forum on the magic carpet you came here on, & dont come back!!
This is exactly why I left plumbing forum- plumbers can't have a healthy discussion without being rude and abusive to each other!
SO back to the OP:
Do you have the latest copy of the regs, OSG and relevant guidance notes?
Do you have a calibrated tester?
Does your PL insurance cover doing electrics?
SO back to the OP:
No, No And No- but that is my point do you need all that for minor works?
If its not notifiable then why would you need all that?
Because you need to test your work before you fire it up. We don't just run the cable and switch on to see if it works. Is that what you would do with a gas installation?
It must be ok if it doesn't go bang?:rolleyes:
Because testing of an alteration ensures it complies with the wiring regs, which in turn should ensure safety of the circuit for continued use. All new work, no matter how small, notifiable or not, should be tested.
It is with wet plumbing!!
What I mean is, why do you need minor works certificate? does it help sell the house? is it a legal requirement, is it required by solicitors when selling or is it just something you give customer?
Who reads the certificate?
The certificate is a record and proof that the alteration has been done to the wiring regs. The issuing of a certificate is a requirement of the regs in itself. Interested parties may include solicitors, insurance agents, estate agents, potential buyers etc.
All electrical work should comply with BS 7671. BS 7671 requires specified electrical work to be accompanied by a Minor Electrical Installation Works Certificate, so to comply you should provide one. Simpless.
And I believe the EAWR stipulate you should keep records of the installation for the life of the installation. Records that include details of the work carried out on it. That would include MEIWCs.
So the best I can do is remove floorboards, chase walls, drill holes in joists.
Why are some NICEIC member approved and some not? is it because they pay more for extra assessments?
I read often that the Yanks swear by the Bang test
They sent a man to the Moon,if it was us we would still be filing the paperwork for the launch :)
Regulations
Thread Tags
jase158,
Midwest,
