K
kas
Ok guys advice needed.
I am swapping over a single electric built-in oven with a similar item, they both require hard-wiring, and are of similar power rating (2145w - 2335w).
The current oven is hard wired with the following grey cable
BASEC 300 / 500 V H 6242Y 6.0
Am I ok to use this cable (which is still in good condition) to hard-wire the new oven.
If so it should be a simple job, what is the max power this cable would be ok for.
Ps -There is a seperate oven isolation switch above the worktop to the left, and its own 32A fuse in the consumer unit.
