Rewire | Page 4 | on ElectriciansForums
Discuss Rewire in the UK Electrical Forum area at ElectriciansForums.net
R
rjwbrown
After a bit of advice/clarification re 18[SUP]th[/SUP] edition of the regulation.
Firstly a bit of background, having a lot of work done on a 70's bungalow for my mother in law, altering the layout, lounge/dinner to a kitchen/dinner with separate lounge, new bath room, new external oil boiler and included a complete rewire.
There have been a few points raised by the electrician of which I found a bit strange.
He wanted to move the meter and I said no as it is fine where it is and I did not want to fall foul of any of the supply company regulations.
I wanted one double pole switch for the oven (Total connected load 3.68KW) and the hob (Total connected load 2.99KW) and he wanted two, both are well within 2 meters of the switch position I had in mind. The reasoning here is glass splash backs and the less holes the better a each hole adds to the cost.
Earth bonding to the water main he wanted the stop cock under the kitchen sink as he said “that’s where they go” and I have opted for a remote (Surestop) one which is plastic and the incoming pipe is plastic, and only picks up copper under the bathroom floor. The reason for picking a remote one is that in the event of a leak an elderly person would have problems with the older brass tap never mind getting to it. Does this earth connection need to be assessable? It is going to be under the floor in an area that is not readily accessible as it will be tiled.
The new main CU is having all RCBOs fitted so I’m thinking that any supplementary bonding is only precautionary rather than a requirement.
Garage supply in armored cable not a problem there and I was going to use a plastic garage CU but he said he would have a problem with the termination but I thought what’s wrong with a metal box along side the CU for the termination of the armored cable.
Any comments welcome good or bad and have I missed anything I need to be aware of.
Rob
I don't understand why you guys are getting at the OP, he sounds clued up eñough to want to be sure his spark is doing the right stuff.
You have no idea if the spark is a spark, if he is 17th qualified or jûst blagging it, Electrical Trainee or time served.
You make your feelings well known about those sorts but when someone wants to be reassured that their spark is doing things right
you hjump on them as well!
Consistent if nothing else
i think you've got one letter too many in this part of your post. i just hope it's the H and not the J!
Well that got some interesting responses, some useful others of no use what so ever.
If you took the scenario where it was said
“just tell me what you want and how, then leave me alone to do it! if you want to get involved..........stick the kettle on!”.
May be someone can answer this,
How is one supposed to know the job will be done correctly?
My view ask questions, probably beyond the remit of most home owners and if you know your stuff it should not be a problem.
I get asked questions all the time and do not have a problem answering and explaining, all be it in a slightly different field (mechanical engineering) so if you have knowledge pass it on, do not just moan about interfering home owners etc.
It's a bit like complaining about the learner driver in front of you on the road, we all had to learn and were probably the same, how easy we forget.
look, life's not black and white. you can never be 100% certain. but if you employ someone with a proven track record and who can provide solid testimonies from previous customers, you should be alright. ask to see his qualifications and examples of his work. ask for a guarantee and a contract stipulating everything you want doing. then get out of his way and let him crack-on.
if you're from an engineering background you should know this.
If I'm stuck behind a learner driver I allow enough time for them to complete their manouvre and maybe try to overtake at the next safe place, I wouldn't wind down the window and try to teach them to drive.
If I take my car to the garage I let them have a look at it, explain what is wrong (which I usually half understand) then leave them to get on with it, trusting that they know what they're doing. I don't go and stand behind them with a Haynes manual asking for a step by step tutorial on exactly what they're doing and an explanation as to what everything means in the manual.
So how are you supposed to know the mechanic fixing your car is doing the job correctly? How do you know it was built correctly in the first place? Do you go to the factory while they're building it and ask them to explain the plans to you? Do you start querying the terminology on the plans and asking if it could be done slightly differently instead?
Or do you just leave them to get on with it?
Nice to hear a customer taking an interest, most of the time only thing i get to hear is after the event when something has been put in the "wrong" place.
A proper sparky should be looking to give the client what they want and keep within the regs. Just because one sparky does it a certain way does not mean there are not alternatives.
Having said that, think the OP needs to think about another sparky, one that has two ears and one mouth, used in that quantity.
I don't have a problem with the customer asking questions. I'm supposed to be the 'expert' with a good knowledge of the regs, and I should be able to explain to the customer why I'm doing something a particular way. If the customer still wants it done differently then, provided that it's safe, I'll do it (costed accordingly); after all, he's paying.
I recon that if you talk to your customers and agree a way forward, you'll be more likely to get a happy customer and therefore repeat business. If you don't have the confidence to discuss the job, you're probably just doing it 'how I've always done it', and not thinking it through (like always bonding to incoming water pipe, rather than determining whether it's actually required).
^^EXACTLY! Nothing worse than a customer who's been on the Internet for half an hour then starts to tell you how to do your job
He wanted to move the meter andI said no as it is fine where it is and I did not want to fall foul of any of the supply company regulations.
You have yet to explain the strange issue quoted above that was in your opening post
The meter and CU are just inside the front door in a porch area on the right hand side of the door in a cupboard and the electrician wanted to move it, I already knew that the meter was not within his remit but he said he had done it before without any problems.
After some thought decided this was not a good idea as the move is the responsibility of the home owner not the electrician or who ever moved it.
The move was not a massive one a matter of a couple of feet, his reasoning was it made the wiring easier to run as it could all be placed in a stud wall but it would be in your face as you walked in the front door.
FYI: The ring mains and other services are under the floor (suspended timber) with the exception of the lighting which is all in the loft space and access from floor level to loft is easy as there is a new stud wall going in which the builders have left open until the cables are run. Do not forget this is a bungalow.
Reply to Rewire in the UK Electrical Forum area at ElectriciansForums.net
Its down to the budget and your experience level - If they cannot pay you cannot work, If you dont know whats safest you shouldn't work - If you...
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
