Rewire | Page 5 | on ElectriciansForums
Discuss Rewire in the UK Electrical Forum area at ElectriciansForums.net
R
rjwbrown
After a bit of advice/clarification re 18[SUP]th[/SUP] edition of the regulation.
Firstly a bit of background, having a lot of work done on a 70's bungalow for my mother in law, altering the layout, lounge/dinner to a kitchen/dinner with separate lounge, new bath room, new external oil boiler and included a complete rewire.
There have been a few points raised by the electrician of which I found a bit strange.
He wanted to move the meter and I said no as it is fine where it is and I did not want to fall foul of any of the supply company regulations.
I wanted one double pole switch for the oven (Total connected load 3.68KW) and the hob (Total connected load 2.99KW) and he wanted two, both are well within 2 meters of the switch position I had in mind. The reasoning here is glass splash backs and the less holes the better a each hole adds to the cost.
Earth bonding to the water main he wanted the stop cock under the kitchen sink as he said “that’s where they go” and I have opted for a remote (Surestop) one which is plastic and the incoming pipe is plastic, and only picks up copper under the bathroom floor. The reason for picking a remote one is that in the event of a leak an elderly person would have problems with the older brass tap never mind getting to it. Does this earth connection need to be assessable? It is going to be under the floor in an area that is not readily accessible as it will be tiled.
The new main CU is having all RCBOs fitted so I’m thinking that any supplementary bonding is only precautionary rather than a requirement.
Garage supply in armored cable not a problem there and I was going to use a plastic garage CU but he said he would have a problem with the termination but I thought what’s wrong with a metal box along side the CU for the termination of the armored cable.
Any comments welcome good or bad and have I missed anything I need to be aware of.
Rob
wasn`t there another thread the other day in here Tel.....goin on about interfearin with bullits and DNO equipment?...lol
bullets are 1 thing. 70 year old lead sheathed cable that's been in the ground for longer than adolph hitler, is another matter.
Well if it was me there as the spark i would of told the client to foxtrot oscar by now as people like him get right up my nose.
Wasnt going to reply as thought the guy was a total muppet but had to say something
Happy New year to all you proper sparks on here and keep your chins and standards up
well you have to move the meter as DNO fitted it bang in the middle of a 2' x2' board so you got no room for anything bigget than a 4 way CU.
Reply to Rewire in the UK Electrical Forum area at ElectriciansForums.net
Its down to the budget and your experience level - If they cannot pay you cannot work, If you dont know whats safest you shouldn't work - If you...
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
