I'm not going to turn a job down as long as it complies.
It's not going to comply unless all plastics exposed externally are UV stable and adequate mechanical protection is achieved.
I'd consider SWA a reasonable solution for external exposed.
Discuss Ring Final CCT - Cable clipped direct to an outside wall in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
charge them the same amount for the cert as you would for the install, fill in everything correctly on the limitations, get them to sign the design!
Reply to Ring Final CCT - Cable clipped direct to an outside wall in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
