Ring or Radial | Page 2 | on ElectriciansForums
Discuss Ring or Radial in the Australia area at ElectriciansForums.net
L
liam b
Hi
Im starting a rewire tomorrow, its a 2 bed terrace, with only 3 sockets downstairs in the living room and 4 upstairs, 2 in each bedroom, maybe one on the landing.
anyway i was going to use rings as thats the norm for me but 3 sockets downstairs on a ring just seems silly, ill be putting the kitchen on a ring as it will have all appliances in there. plus upstairs 4/5 sockets again seems a waste of time/cable
is it bad practice to use radials where normally a spark would expect a ring?
whats your thoughts?
cheers
Never tried with 4mm radials, think there's something in the back of my mind saying you'll have a right job terminating the cables, but there you go.
I tend to do 99% of jobs as ring for kitchen and utility if seperate, then 20 amp radials for lounge and bedrooms. If only a 2 up 2 down then 1 radial is sufficient for both beds IMO. If larger I may run 2 radial for upstairs.
i have not had a problem terminating the 4mm although a mate of mine did have with 6mm on the spec they had from a council in the kitchens. imagine 3x 6mm in the fcu above the kitchen work surface. he was spitting after that one :D some wierd council specs out there
I have done many 4mm radials and never had a problem terminating.
Fair comments, may have to start trying out the 4mm radials in the future then.
Reply to Ring or Radial in the Australia area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
