Chr!s
I think if it were it would be self evident
Why would you think that? Sometimes a fault may require heat fro example for a short to be produced, or maybe a leak on the washer.
Discuss scenaro in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Because the fault would only occur when that appliance was used in this case its random
But would'nt it also take out the fuse?
Give the op a bit of credit
When you treat yourself to a clamp meter try a push the boat out and get one that also does earth leakage as well good for tracing RCD faults you won't regret it IMO!!!!
so jurasic spark, if a 2.5mm spureded cable IS overloaded, MCB will trip? even though its a 32A breaker.
Reply to scenaro in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
