Guest viewing is limited
View the thread, titled "Seperate / Integral earth CPC on 400A supply" which is posted in Electrical Wiring, Theories and Regulations on Electricians Forums.
Could you post the cable calc for the two options. IMO an external Cpc would be electrically preferential but I guess the brains at IET think otherwise.
I think there is a bit of confusion here, the thing I was trying to highlight was that the software said it was ok to use a 5c cable with an integral earth conductor, but not ok to use a 4c cable with a supplementary earth of the same size.
I have been thinking about this and and the only thing that comes to mind is the programme assuming the cpc will pass through a separate hole to the line conductors which would not happen if it were a core of the cable which may under fault conditions be problematic, maybe.
Reply to the thread, titled "Seperate / Integral earth CPC on 400A supply" which is posted in Electrical Wiring, Theories and Regulations on Electricians Forums.
