davesparks
I'm not playing into anyone's hands on here read it again mate, I've done my test and inspection in college, I don't need to test anyone else work but mine! I asked what's the recommended mcb to use not what I own or what I have knowledge of! Once I've installed the entire thing I'll run my dead tests then do a live test, I haven't asked anyone how to do tests! Getting right off topic.
The correct MCB to use is the one you selected after calculating the maximum demand after diversity and before calculating the size of the cable you used.
What method did you use to decide that 6mm cable was correct for your installation?
