Should I use 1mm or 1.5mm earth in domestic lighthing? | on ElectriciansForums
Discuss Should I use 1mm or 1.5mm earth in domestic lighthing? in the Domestic Electrician Forum area at ElectriciansForums.net
Hi,
I need to earth a replacement faceplate to a steel back box in the wall.
Should I use a 1mm, or 1.5mm sleeved cable for the job?
The earth in the 2.5 is actually 1.5, but 1.5 will be better than 1mm. If you use 2.5mm that may be too big to fit in the switch earth terminal
I will go out and buy a metre of 2.5mm t&c and sleeve it yellow and green.
I just want to be safe.
just use this and put green stripes on it.
Reply to Should I use 1mm or 1.5mm earth in domestic lighthing? in the Domestic Electrician Forum area at ElectriciansForums.net
Ouch. Danger notice to customer in my book.
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
