Hi,
I need to earth a replacement faceplate to a steel back box in the wall.
Should I use a 1mm, or 1.5mm sleeved cable for the job?
The earth in the 2.5 is actually 1.5, but 1.5 will be better than 1mm. If you use 2.5mm that may be too big to fit in the switch earth terminal
Should I use 1mm or 1.5mm earth in domestic lighthing?
Domestic Electrician Forum
Thread Tags
midiman,
telectrix,
