Show your insulated tools | Page 2 | on ElectriciansForums
Discuss Show your insulated tools in the Electrical Tools and Products area at ElectriciansForums.net
The OP had a voltage tester on that table full of lovely gear....not that he needs it...:smug:
Have any of them been used? None of mine look like that!
Presumably they have been used, but if they were not clean and with no visible damage on them then they would not be permitted to be used as the insulation rating could be compromised.
Obviously it is all down to the company's risk assessments and method statements/codes of practice but insulated tools for live working will generally need to be clean and undamaged with regular inspections and testing
Obviously it is all down to the company's risk assessments and method statements/codes of practice but insulated tools working will generally need to be clean and undamaged with regular inspections and testing
I agree with you again.
I've altered the quote a little, and I think that principle should be applied to all tools
I agree that they would eyed to be undamaged and regularly inspected but I've been working with dno's for years and never seen a guys tools looking in that mint condition. a couple of mine are in that good nick but not all.
Hi everybody, i want to show my insulated tools and i would like to see yours,my tool are Facom. Knipex and Cimco.
[ElectriciansForums.net] Show your insulated tools
Not been that busy then? only kiddin nice set of tools
Like this:
Knipex 98 62 02 VDE Insulated Snipe Long Nose Plastic Pliers 220mm Fuse Pulling | eBay
I've bought some Knipex stuff from this seller without a problem.
Yeah gave to agree, this guy xpn1 on ebay is good and have also used him a lot
Yeah that's the kiddies, wonderful for doing such terribly naughty things as disconnecting or connecting a single circuit in a live DB. Also very good for generally manipulating cables in a small enclosure due to them being a little softer in their grip on the insulation.
Well the collection is looking a bit better, thank you. (but my wallet is not:sad3:).
Selection is now Aldi, B&Q, random ebay seller :stuart:(with recommendation)
Reply to Show your insulated tools in the Electrical Tools and Products area at ElectriciansForums.net
A problem putting multiple cores into a ferrule is when you need to do testing or fault finding. You can't just drop the ends out of the terminal...
Not used if tor real yet but it has quite a nice fine ratchet action. The forwards/backwards toggle is a bit fiddly to operate and it lacks a...
