Show your insulated tools | Page 3 | on ElectriciansForums
Discuss Show your insulated tools in the Electrical Tools and Products area at ElectriciansForums.net
I hope you're not planning to do terribly naughty things now - just because davesparks does!
Sent from my iPhone using Tapatalk
You are a breed apart - you pyro boys, one day we'll all get to 'light the blue touch paper and retire' but this government probably won't let it happen until we are 85!
Sent from my iPad using Tapatalk
My tools
Pliers are Schneider
Side cutters Knipex
Screw drivers are a mix of Bahco, Draper. My most used driver is 4mm x 100mm is CK with a cheap backup bought from Screwfix.
Long nose pliers bought from Wickes
My pliers used to be Knipex but they were borrowed by an electrician when I was testing for Schneider so my site contact replaced them.
I have a hotch potch of VDE tools. I have a set of 1KV screwdrivers made by 'Futur' or at least that's what's printed on the handle. They were cheap even though they came from somewhere on the spice route (about 15 quid for the set) but have actually lasted very well. Apart from them I splashed out on Knipex VDE side cutters and long nose pliers, a no-name VDE adjustable spanner and a few VDE allen keys for common MCCB and ACB terminals. Not sure if my gloves, apron and Ex rated flashlight count as VDE.
Don't mind me while I bump some old threads. Just doing the rounds. Ignore the thread if it's not current topic, it'll soon drop off the list, but if the thread interests you, feel free to reply. :)
Reply to Show your insulated tools in the Electrical Tools and Products area at ElectriciansForums.net
A problem putting multiple cores into a ferrule is when you need to do testing or fault finding. You can't just drop the ends out of the terminal...
Not used if tor real yet but it has quite a nice fine ratchet action. The forwards/backwards toggle is a bit fiddly to operate and it lacks a...
