Signs of house needing a rewire?? | Page 2 | on ElectriciansForums
Discuss Signs of house needing a rewire?? in the UK Electrical Forum area at ElectriciansForums.net
H
hbrad92
I have had a call from a friend asking me to come check his wiring in his house and to basically tell him if he needs it rewired.
I know the fusebox will need replacing as he has the old rewireable cartridge fuse set up.
What a wanted to find out is what are the obvious or most common signs of a rewire being needed? I understand most oldish properties have white cable with old red and black colours etc, but is that an instant sign of a required rewire?
I plan to test the installation regardless of whether it needs rewiring or not when I upgrade the fusebox, but the bloke wants answers and prices asap. That leads me to my next question of how much should a rewire come to roughly. its a small 2-3 bed house and will only require basic sockets switches and lights etc (nothing fancy).
Any help would be much appreciated!
Now is HE a Sparky?
A member for 3 years Pete, I despair I really do, No testing, No visual checks, the customer is concerned yet he is asking what info we can give to assess whether the house needs rewiring or not as he isn't sure, Honestly I am absolutley gobsmacked, I can bearly believe it.
Keep it calm as this could be an interesting debate... count to ten and BREATHE!!!
Please get yourself on a testing and inspecting course and read section 6 of the BGB, until then please do not attempt to take any work on in a domestic premises for the sake of the house owners.
He is just going out on his own and wants some advice. If he has been with someone else for years he may have mainly just done install. Maybe he is a really good installer but has not priced jobs before and his old boss did the testing.
Now I know why I wanted to jack arghhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Reply to Signs of house needing a rewire?? in the UK Electrical Forum area at ElectriciansForums.net
Definitely, although most likely within the accessories. I've often found that once accessories are disconnected the cabling IR is fine. Sometimes...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
