Single phase board with rcbo's | on ElectriciansForums
Discuss Single phase board with rcbo's in the UK Electrical Forum area at ElectriciansForums.net
I would also put some female brass bushes on those males to avoid nicking those singles coming in from the grid switch.
Take a bit of time to dress the cables properly. That lot looks like it's been bunged together in a hurry. Why is the SWA entering the cu at a 30 degree angle?
Strip of all the outer sheathing on the twins then separate the cables into groups of cpc's, neutrals and lives. Terminate all cpc's followed by neutrals then lives.
Although this isn't an RCBO board, here's an example of one of my boards done a couple of years back, this isn't perfect and I knocked one of the lives out of straight before taking the picture but the job took an hour and a half start to finish [apart from testing], someone got let down by their usual sparks and the place was being let two days later so I ended up doing this at 8pm on a Friday night !
[ElectriciansForums.net] Single phase board with rcbo's
Dress the cables neatly, take a bit of time to do the job to a good standard instead of that mess.
Cleat the SWA so that the gland isn't stressed like that
Put the RCBO earths in the right places
and ferrule the ends.
tidy except the visible copper on the incomers.:28:
I did cut 5mm of copper off the tails and re-do them, only took the picture to e mail the owner of the place to confirm the job was done and put his mind at rest as he was stressing about the tenants on the way and no working electrics ! :smiley2:
Reply to Single phase board with rcbo's in the UK Electrical Forum area at ElectriciansForums.net
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
Sockets will probably be ok on one, a little inconvenient in the event of a fault though, I'd probably like a 7th rcbo in. Wonder if hes linked...
7K
suffolkspark
S
