Smoke/heat alarm requirements on a rewire?
What are the smoke and fire alarm requirements when carrying out a full rewire on a domestic property?
I’ve had my napit assessment today at a families house that I rewired last year tested everything is good. But the assessor mentioned that fire alarms systems with a minimum of LD2 system is required if you rewire an entire property.
I can’t seem to find any information on this. Can anyone point me where to look on the type of systems required for different types of properties please?
unless its a new build or the customer requires it or advise it.
It’s not a new build no, I wouldn’t say they require it but I did advise to put some in but he said no he doesn’t want any he will buy some battery ones himself. So it’s not actually a requirement?
Should have asked the assessor where it is stated.
He said it’s not in the bs7671 but it’s somewhere in the building regulations. I’ve tried to look for it using the find in a page tool on the browser using keywords but cannot find any information.
UNRELATED TO REPLIES AND THREAD
He also said on an EICR with no RCD protection if cables are buried less than 50mm it’s a C2 but I questioned it and said wouldn’t that be a C3 because at the time it complied with the current regs and did not need RCD protection? He was saying to me if you’re between 2 options on coding then go for the harsher option as you are covered if anything goes wrong. He brought up the reasons why RCDs are out and the story about that member of MPs daughter dying.
its a pitty you shoud have pulled what the NICEIC REGARDING NO RCD code 3 IET absence of protective rcd cables buried in the wall .
I just used to argue with them. If I was told that I just wouldn't agree with them no matter how much they waffled on as to why it was a Code 2.
Should have asked where it was in the Building Regulations or if you have their email ask them now.
Yeah he mentioned something about the niceic giving it a code 3 can’t remember what exactly he said, he was waffling a lot lol sometimes going in circles. Was a nice guy though.
Yeah I’m going to have to call them up tomorrow because that bugged me when he told me that. I was thinking ffs I now need to try get hard wired smokes and heats in a fully furnished house, to be fair most would easy enough.
So from what you’re saying of there’s no regs or anything stating fire system is needed?
I doubt that would come out of him, saying NIC they would put a code 3,
What should have said IET would give it a coded 3, they can't make up the own rules, when the IET make the Bible.
I mean the coding thing is supposed to be an engineering judgement to a certain extent so the way he was explaining it I get why he would c2 no Rcd for cables less than 50mm. If someone drills into a cable and it pinches only the live and they touch the metal casing of what they put up and an exposed conductive part then they could die I guess which is basically the example he gave me about the MPs daughter.
So just to touch on the topic of the thread… the thing about needing LD2 fire system on a rewire is nonsense? I’ve just looked through aicos website and it mentions LD2 is a minimum in Scotland and wales but not England.
It is nonsense unless the building has had extension works or has undergone a material change then smoke detection is not a necessity albeit I would have probably put it in place. I believe the minimum for your average dwelling is Grade D2 Category LD3 according to Approved Document B.
You can and I do blame the snp for that and there cosy select friends .
My napit inspecter pulled me up for bonding the water pipe when it came in to the building in plastic but I explained the customer had a boiler shed 10 metres from house with buried flow and return copper pipes .he also thought that in a few years time rcd testing on new consumer units will be proved by just pressing the test button due to manufacturers constantly receiving what is deemed to be a faulty rcd/rcbo when there was nothing wrong with them.i must say I have to agree .if there designed and built to a standard why should they require further testing ,I realise they play an important safety role but if there straight out the box ? If tt system was in place then absolutely or required for fault protection but what test do you do on a 60898 mcb on initial verification or the main switch other than checking when it's off its off .
It's always a tragedy when someone dies due to a fire or electrical fault and the industry is right to maintain high safety standards but the same cannot be said about our road network especially in Scotland. I don't know exact figures but there must be hundreds of fatalities on roads ,speed limits etc not fit for purpose but the same scrutiny is not placed on the road network.theres pot holes near me you could have a bath in .
You and try to say to the customers regarding the consumer units, two jobs last week no protection, RCD, just main switches and isolation switch only.
