Guest viewing limit reached
Hi, The walls have been chased out and he fitted 25mm back boxes and to be fair you can't really go any deeper but one socket on a ring is feeding a spur so three cables and yes you can fit it in but really id like a bit more room.
Are there any sockets that have very thin connections on the back?
Not going too off topic but technically now you mention it an unfused supply off a ring? maybe theres a reg being broken there.
If you are talking about USB 13A sockets, since 2016 when the socket British Standard was revised to cover built-in electronics, the design has to incorporate a fusible link or fuse, and the psu must be SELV, meeting creepage and clearance distances and transformer insulation requirements etc. etc.
USBs got off to a bad start before that revised standard, when the market was flooded with dubious products, though I think China also makes 'proper' ones now.
But these days I like to think if you buy an approved product from a reputable manufacturer/source, there should no longer be a problem!
Newer technology allows a phone or tablet you plug in to negotiate with the USB charger what voltage/ current it wants.
I guess you could say that's that's an added safety feature, or something else to go wrong!
I'd be interested to know if these sockets do have a fused link or fuse.
But really I'm only referring to Rings etc Even if you took a selv spur of a Ring you have to fuse it.
Fused plugs are only required in the UK where we use Rings.
the flex is protected by the Fuse/MCB at the DB on a radial.
Only in specific cases where MCB and cable are specified together to meet adiabatic limit, etc.
That is why they often have thicker cables and limits on MCB for non-UK systems. We now also have thicker more expensive cables on most equipment because no one makes just for the UK market any more!
The collar/spacer thing worked great. This forum always has the best advice.
The only thing, I bought some longer screws from a well know distributors and they basically stripped the thread of the backbox. Where do you buy 3.5 screws?
Reading
United Kingdom
Trainee Electrician
Socket with slimest back connections?
Mark Wright,
Mike Johnson,
