Socket with slimest back connections?
Hi, The walls have been chased out and he fitted 25mm back boxes and to be fair you can't really go any deeper but one socket on a ring is feeding a spur so three cables and yes you can fit it in but really id like a bit more room.
Are there any sockets that have very thin connections on the back?
is the socket one of those awful flat plate abortions. these need deeper boxs, usually 35mm.
Hi, thanks for your reply :)
At first he wanted a USB socket he bought but there was no way that was going to fit, the current socket I'd say the connection on the back are protruding about normal. What I'm wondering if anything exists with very slim connections on the back.
BG USB sockets will fit on a 25mm back box, although some care with dressing 3 cables would help.
The problem I had with the previous USB socket is it didn't have that notch at the bottom where the cables enter the box.
I'm probably being a bit picky but if anything exists thinner than the two pictured above that would be great.
I think the usb charger thing was down to poor quality products, which includes the socket outlet, not just the usb charger, if I recall. I would use electrical accessories from a reputable manufacturer, then the usb charger shouldn’t be a problem.
I’ve also used those spacers before in such circumstances. If I recall, they were a bit fiddly to fit, but did the trick. Obviously need pairing with the socket manufacturer.
Mark Wright,
Mike Johnson,
