Socket with slimest back connections? | on ElectriciansForums
Discuss Socket with slimest back connections? in the UK Electrical Forum area at ElectriciansForums.net
Reading
Hi, The walls have been chased out and he fitted 25mm back boxes and to be fair you can't really go any deeper but one socket on a ring is feeding a spur so three cables and yes you can fit it in but really id like a bit more room.
Are there any sockets that have very thin connections on the back?
Hi, thanks for your reply :)
At first he wanted a USB socket he bought but there was no way that was going to fit, the current socket I'd say the connection on the back are protruding about normal. What I'm wondering if anything exists with very slim connections on the back.
The problem I had with the previous USB socket is it didn't have that notch at the bottom where the cables enter the box.
[ElectriciansForums.net] Socket with slimest back connections?
I'm probably being a bit picky but if anything exists thinner than the two pictured above that would be great.
I hate the USB sockets . `Unless they are a lot better , i have heard too many stories of them not be safe enough for charging ??
In what way unsafe?
Where have you heard the stories?
Mobile phone forums etc etc . Something about many of them not having much of a safety regulator etc built into them .many people saying use a plug in charger is far safer for the protection of the item been charged etc ??
I think the usb charger thing was down to poor quality products, which includes the socket outlet, not just the usb charger, if I recall. I would use electrical accessories from a reputable manufacturer, then the usb charger shouldn’t be a problem.
I’ve also used those spacers before in such circumstances. If I recall, they were a bit fiddly to fit, but did the trick. Obviously need pairing with the socket manufacturer.
Reply to Socket with slimest back connections? in the UK Electrical Forum area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
