G
Geordie Spark
But crucially, with the wringing of the neck part after the money coming back part :lol:
Oh aye ...... must get things in the correct order. :wink5:
Is it me or are there no de-rating factors for flex, or have I gone blind...
Is the stuff not designed to be free in air and only have some minor weight bearing capability for supporting lamp holders etc...
Or am I talking complete bollox...
Also good for lashing the kidsIt's also useful for lashing stuff to the roof rack.
Would it not be prudent to apply some derating though? If something can carry 10 amps but is thenfor example, buried under a mountain of tickly wool it's going to have an effect on itIs it me or are there no de-rating factors for flex, or have I gone blind...
Very true, I would use the trusty 0.5 method just to be sure. But serious question, are there any installation methods/factors for flex?Would it not be prudent to apply some derating though? If something can carry 10 amps but is thenfor example, buried under a mountain of tickly wool it's going to have an effect on it
There's nothing to say you can't hard wire in flex, there was a long thread about it a few months back and the general concensus was that it's acceptable. You just wouldn't though, would you?
Like Geordie said though, the tiles will be warm in winter when wiping over to keep them clean. Well it's only a few wires man, what can possibly go wrong?especially if IT IS 1.0mm on a 32A breaker
they appear to be wired as a ring which i can connect into and i'm changing the CU so would i get away with a 20 A MCB?
Did your limited PIR involve you looking inside the consumer unit?I did a limited PIR before but didn't take every socket off the wall.Had no reason to suspect that it had been done in flex.I assume the homeowner either did it himself or a mate of the kitchen fitter did it. either way, it makes it difficult to remedy.
How do you know they are wired as a ring, do the cables go back to the consumer unit on its own MCB?
If you answered yes to my first question above. You should have looked further into it and made the customer aware at the time, looks like you have shot yourself in the foot!
Down rate the circuit or you will have to remove the tiles, its an easy job to remove them with out breaking them.
Not when I clag them on it isn't !!! :winkiss:
I thought you northeners used chewing gum if the gripfill has run out!
