Well if you had EWI as a primary measure then a boiler would get ECO funds too .
the green deal is also tied to the electric meter and not you plus there is a LOSE credit check so it helps alot of people out....
what walls have you got ?
if they are soild then you could get eco funding towards the wall then the boiler and other measures become avilable under ECO too.
this includes
[TABLE="width: 769"]
[TR]
[TD="class: xl75, width: 287, bgcolor: transparent"]Solid Wall Insulation[/TD]
[TD="class: xl72, width: 323, bgcolor: white"]IWI (solid): pre 1967 England & Wales, pre 1965 Scotland[/TD]
[TD="class: xl78, width: 272, bgcolor: #A6A6A6"]IWI_solid_pre1967_E&W_pre1965_S[/TD]
[TD="class: xl87, width: 72, bgcolor: #00B050"]E[/TD]
[TD="class: xl68, width: 72, bgcolor: #00B050"]E[/TD]
[/TR]
[TR]
[TD="class: xl74, width: 323, bgcolor: white"]IWI (solid): from 1967 E&W, from 1965 Scotland[/TD]
[TD="class: xl79, width: 272, bgcolor: #A6A6A6"]IWI_solid_from1967_E&W_from1965_S[/TD]
[TD="class: xl88, width: 72, bgcolor: #00B050"]E[/TD]
[TD="class: xl99, width: 72, bgcolor: #00B050"]E[/TD]
[/TR]
[TR]
[TD="class: xl73, width: 323, bgcolor: white"]EWI (solid): pre 1967 E&W, pre 1965 Scotland[/TD]
[TD="class: xl79, width: 272, bgcolor: #A6A6A6"]EWI_solid_pre1967_E&W_pre1965_S[/TD]
[/TR]
[TR]
[TD="class: xl74, width: 323, bgcolor: white"]EWI (solid): from 1967 E&W, from 1965 Scotland[/TD]
[TD="class: xl79, width: 272, bgcolor: #A6A6A6"]EWI_solid_from1967_E&W_from1965_S[/TD]
[/TR]
[TR]
[TD="class: xl84, bgcolor: white"]Internal non-solid Brick Wall Insulation[/TD]
[TD="class: xl79, width: 272, bgcolor: #A6A6A6"]IWI_non_solid[/TD]
[/TR]
[TR]
[TD="class: xl85, bgcolor: white"]External non-solid Brick Wall Insulation[/TD]
[TD="class: xl80, width: 272, bgcolor: #A6A6A6"]EWI_non_solid[/TD]
[TD="class: xl89, width: 72, bgcolor: #00B050"]E[/TD]
[TD="class: xl100, width: 72, bgcolor: #00B050"]E[/TD]
[/TR]
[TR]
[TD="class: xl70, bgcolor: transparent"]Park Home External Wall Insulation[/TD]
[TD="class: xl81, width: 272, bgcolor: #A6A6A6"]EWI_Parkhomes[/TD]
[TD="class: xl90, width: 72, bgcolor: #00B050"]E[/TD]
[TD="class: xl101, width: 72, bgcolor: #00B050"]E[/TD]
[/TR]
[TR]
[TD="class: xl70, bgcolor: transparent"]Cavity Wall Insulation[/TD]
[TD="class: xl71, width: 323, bgcolor: white"]Standard CWI[/TD]
[TD="class: xl81, width: 272, bgcolor: #A6A6A6"]Standard_CWI[/TD]
[TD="class: xl91, width: 72, bgcolor: #00B0F0"]S[/TD]
[/TR]
[TR]
[TD="class: xl75, width: 287, bgcolor: transparent"]Hard To Treat Cavity Wall Insulation [/TD]
[TD="class: xl75, width: 323, bgcolor: transparent"]HTTC: Cavity wall insulation solution[/TD]
[TD="class: xl78, width: 272, bgcolor: #A6A6A6"]HTTC_CWI_solution[/TD]
[/TR]
[TR]
[TD="class: xl67, width: 323, bgcolor: transparent"]HTTC: Solid wall insulation solution[/TD]
[TD="class: xl80, width: 272, bgcolor: #A6A6A6"]HTTC_SWI_solution[/TD]
[/TR]
[TR]
[TD="class: xl107, bgcolor: transparent"]Loft Insulation[/TD]
[TD="class: xl69, width: 323, bgcolor: transparent"]Loft Insulation Ceiling Level Virgin[/TD]
[TD="class: xl78, width: 272, bgcolor: #A6A6A6"]LI_ceiling_level_virgin[/TD]
[TD="class: xl92, width: 72, bgcolor: #00B0F0"]S[/TD]
[/TR]
[TR]
[TD="class: xl66, width: 323, bgcolor: transparent"]Loft Insulation Ceiling Level Topup[/TD]
[TD="class: xl79, width: 272, bgcolor: #A6A6A6"]LI_ceiling_level_topup[/TD]
[TD="class: xl93, width: 72, bgcolor: #00B0F0"]S[/TD]
[/TR]
[TR]
[TD="class: xl66, width: 323, bgcolor: transparent"]Loft Insulation Rafter[/TD]
[TD="class: xl79, width: 272, bgcolor: #A6A6A6"]LI_rafter[/TD]
[/TR]
[TR]
[TD="class: xl67, width: 323, bgcolor: transparent"]Room in Roof Insulation[/TD]
[TD="class: xl80, width: 272, bgcolor: #A6A6A6"]RIRI[/TD]
[TD="class: xl94, width: 72, bgcolor: #00B0F0"]S[/TD]
[/TR]
[TR]
[TD="class: xl111, bgcolor: transparent"]Other Insulation[/TD]
[TD="class: xl76, width: 323, bgcolor: transparent"]Flat Roof Insulation[/TD]
[TD="class: xl82, width: 272, bgcolor: #A6A6A6"]FRI[/TD]
[TD="class: xl95, width: 72, bgcolor: #00B0F0"]S[/TD]
[TD="class: xl102, width: 72, bgcolor: #00B050"]E[/TD]
[/TR]
[TR]
[TD="class: xl66, width: 323, bgcolor: transparent"]Under Floor Insulation[/TD]
[TD="class: xl79, width: 272, bgcolor: #A6A6A6"]UFI[/TD]
[/TR]
[TR]
[TD="class: xl66, width: 323, bgcolor: transparent"]Hot Water Cylinder Insulation[/TD]
[TD="class: xl79, width: 272, bgcolor: #A6A6A6"]HWCI[/TD]
[/TR]
[TR]
[TD="class: xl66, width: 323, bgcolor: transparent"]Pipework Insulation[/TD]
[TD="class: xl79, width: 272, bgcolor: #A6A6A6"]PWI[/TD]
[/TR]
[TR]
[TD="class: xl66, width: 323, bgcolor: transparent"]Draught Proofing[/TD]
[TD="class: xl79, width: 272, bgcolor: #A6A6A6"]DP[/TD]
[/TR]
[TR]
[TD="class: xl66, width: 323, bgcolor: transparent"]Window Glazing[/TD]
[TD="class: xl79, width: 272, bgcolor: #A6A6A6"]WG[/TD]
[/TR]
[TR]
[TD="class: xl67, width: 323, bgcolor: transparent"]Passageway Walk-through Doors[/TD]
[TD="class: xl80, width: 272, bgcolor: #A6A6A6"]PWWD[/TD]
[/TR]
[TR]
[TD="class: xl107, bgcolor: transparent"]Boiler[/TD]
[TD="class: xl69, width: 323, bgcolor: transparent"]Boiler: Replacement qualifying boiler[/TD]
[TD="class: xl78, width: 272, bgcolor: #A6A6A6"]QB_Replacement[/TD]
[TD="class: xl86, width: 72, bgcolor: transparent"] [/TD]
[TD="class: xl103, width: 72, bgcolor: transparent"] [/TD]
[/TR]
[TR]
[TD="class: xl66, width: 323, bgcolor: transparent"]Boiler: Repair qualifying boiler 1 year warranty[/TD]
[TD="class: xl79, width: 272, bgcolor: #A6A6A6"]QB_Repair_1_year [/TD]
[TD="class: xl96, width: 72, bgcolor: transparent"] [/TD]
[TD="class: xl98, width: 72, bgcolor: transparent"] [/TD]
[/TR]
[TR]
[TD="class: xl66, width: 323, bgcolor: transparent"]Boiler: Repair qualifying boiler 2 year warranty[/TD]
[TD="class: xl79, width: 272, bgcolor: #A6A6A6"]QB_Repair_2_year [/TD]
[/TR]
[TR]
[TD="class: xl77, width: 323, bgcolor: transparent"]Boiler: Installation of a Non qualifying boiler[/TD]
[TD="class: xl83, width: 272, bgcolor: #A6A6A6"]Non_QB_installation[/TD]
[TD="class: xl97, width: 72, bgcolor: transparent"] [/TD]
[TD="class: xl104, width: 72, bgcolor: transparent"] [/TD]
[/TR]
[/TABLE]
