Some advice adding sockets | Page 4 | on ElectriciansForums
Discuss Some advice adding sockets in the UK Electrical Forum area at ElectriciansForums.net
Wolverhampton
Hello
I'm looking at adding more sockets to a bedroom, I notice the existing single socket has to cables running into it, would it be ok to add twin sockets to the end of each cable or do i need to add another bit of cable to complete the existing circuit?
Thanks for any advice
I get what you mean now...
I'm not sniping mate. If what I'm doing is classed as 'sniping' then maybe it should be directed at the person who started the sniping.
Meant to be a joke Spoon sorry if I was misleading you, don't know how to post to myself, cus I was the one being accused of sniping, I think, now I'm confused, got to go and fix a curtain rail for an old Lady now, laters.
No worries mate.. I'm happy, I'm off work for a week.. (Looking after my lad who bust his leg)
Folks. Can we turn the wick down on this please??.
IIRC I typed my response to the OP on my iPhone. If you've tried it, one cannot be as expansive as we would like when composing something. My thumbs don't appreciate typing 2000 words to express everything that one should consider when undergoing an electrical task.
I've been sparking a loooong time so I am well aware of the various options that there may be when looking at any sort of wiring. I attempted to simplify my (I thought) helpful response by describing what he would most likely find when he looked at the back of the socket (more than likely a ring final). Knowing there was also the potential of the socket(s) being a spur with a spur from it, or a radial I qualified my reply by saying that "If there are two cables, then it is likely that the original socket is on a ring final circuit. But you would need to test if this is the case."
I had hoped that this would be sufficient to head off the expert pedants, who inhabit forums like this, who seem to spend more time picking holes in any response, rather than being helpful.
@Pete999 . My sniping post was not aimed at you. But I do know exactly who lit the flame! I await my opportunity to respond in kind.
Often I will put a little something in a post to tweak a bit of a response from the OP.
Something like the OP says "can you tell me how to test if the socket is on a ring final".
To which we respond "What sort of test equipment do you have"
OP says "I've got a neon screwdriver"
We reply "Get yourself a multimeter".
etc......
I guess, at the end of this 4 page tirade, the end result is that the OP is having an electrician to advise him.
I'll get in touch with my electrician and get more advice from him, thanks
Time to move on?
Love and kisses to most of you
TTC
etc......
Time to move on?
TTC
Looking forward to my kiss... :hearteyes::hearteyes::hearteyes:
etc......
Time to move on?
TTC
There wouldn't have been a problem if you'd used "might be a ring final" rather than "likely to be a ring final" as that is simply misleading as it suggests that the number of conductors indicate this when in fact they do not.
Are we still going on about this. TTC's comment is correct. As the majority of circuits in domestic properties are ring then 'likely' is correct, as is 'might'
Just to check, do you mean two cables?
If there are two cables, then it is likely that the original socket is on a ring final circuit. But you would need to test if this is the case. you'll need a multimeter that can test resistance and mains voltage. Do you have one?
As it is a ring, it is best to add the new sockets and unclude them as part of the ring.
You can add a socket to a ring as an addition (known as a spur) but you can only have one spur. it is not permitted to have a spur from a spur.
Sorry. Unclude?
Reply to Some advice adding sockets in the UK Electrical Forum area at ElectriciansForums.net
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
