SPD in commercial offices | Page 3 | on ElectriciansForums
Discuss SPD in commercial offices in the UK Electrical Forum area at ElectriciansForums.net
London
Surge protection is now semi-mandatory in domestic (there are get out clauses).
Is SPD mandatory, or semi-mandatory, in commercial offices?
Having seen a hospital take a substantial lightning strike with a repair bill of circa ÂŁ500,000 and about 4 - 5 days disruption there was a full risk assessment done on the future risk of it happening again the results of which concluded that the cost (around ÂŁ600,000) of installing the necessary protection across the site versus the strike risk was not a viable spend having had no documented strikes in the previous 40 - 50 years and a calculated future strike risk of 1 sometime in the next 44 to 400 years
Sounds like the NIC trying to make a point and help the manufacturers sell more, I'm surprised the NIC are not insisting on professional indemnity for contractors in case they fit the wrong type of SPD
Anyone for efficacy insurance if the SPD fails to operate under surge / strike conditions
I've seen a lot of surge arrestors fitted on intruder alarm comms kit where the installer didn't bother to connect them to a suitable earth so it made them a bit useless
I've worked on a number of sites with rooftop comms kit and while installing comms kit I got into the habit of doing a quick test on the LPS down lead after we had some interference problems on one site where all the comms cables going to a number of buildings were earthing the LPS at the indoor units because the LPS down lead connection to the earth rod was broken and this was on an LPS that had been tested and certified some 10 months earlier the customer was adamant that it was ok and waved the certificate at me so I got a spade out and exposed the corroded LPS earth connections and then had to more or less drag him out of his office across the site to show him the problem that we had found
Based on what risk assessment and likely hood of it actually happening
When you look at the cost of an SPD I suppose it could be classed as an insurance policy that could sit there for many years and may never ever be needed so how do you justify the cost to the customer. As installations are altered and modified should the risk assessment be revisited to confirm that the type of SPD's installed are suitable for what may be a changed risk within the installation or whether the changes mean an SPD should be installed, which is something that no doubt will be addressed in future guidance
The combined industry experience of this forum probably runs to many hundreds if not thousands of years so the question is how many jobs have members been to where SPD's may have or would have prevented equipment damage and then would the cost of installing SPD's v's the replacement / repair cost of the equipment and disruption caused made it a cost effective decision to install SPD's
Personally in all the years I have worked in the industry I have only seen less than a handful of incidents that may have benefited from an SPD being installed so why is the push now to suggest that sites are at a much greater risk
At 12 mins John Ward explains why these day SPD is important. Dave Savery on one of his vids fitted SDP under an assumption spikes were causing expensive LED lamps to fail too frequently. It was fitted then no problems. How many expensive pcb boards in boilers would have been saved if SDP was fitted? Not to ention being cold and no hot water. mmmm Expensive components may have failed, yet we do we attribute the failure to a spike!
Lightening can strike the earth then affect underground cables quite frequently giving spikes. There does not need to be a full building strike or a direct strike onto a cable. These frequent strikes can be arrested by the SPDs.
Between 1942 and 1977, Sullivan was hit by lightning on seven occasions and survived all of them.
A really scientific approach to solve a problem then, so lamps failed then they didn't after the SPD was fitted so could it have been..............................a bad batch of lamps!
It is one of those situations were a power quality analyser with a before and after analysis may have given it a bit more credibility
Most of the failed boiler PCB's I've seen are down to crap soldering during manufacture causing high resistance joints that overheat and burn the board
Did he have an SPD fitted??
That approach worked. I am not sure if he said he contacted the local weather people to see if there were many lightning strikes about.
Interesting comment on John Ward's vid......
Thanks John, this is a great video, really helpful to explain the use of and requirement for surge protection. Very few people really realise the true extent & cost of damage caused by over voltage issues, one reason for that is that the UK insurance industry is very tight lipped about these things. In Germany this is not the case the insurance industry makes information freely available and they suggest that from all claims of "electrical or electronic damage" over voltage / surge issues are responsible for 31% of the claims. That is a huge figure, for anyone reading this and thinking "he's an idiot, I've never seen anything like that level of damage" ....well how do you know? Over voltage damage is not always immediate and spectacular, there may not be a huge bang and plumes of black smoke.
You can have several incidents over a few weeks and it would lead to wear and tear, then one day flick a switch on and the equipment doesn't work. Do you immediately think "oh that must be wear and tear fro over voltage events" of course you don't. You think "oh that's broken, more money to replace it /repair it". SPD's offer longer life spans for equipment, increased levels of availability, reduction in down time and less maintenance. They are like "electrical life assurance for equipment".
Reply to SPD in commercial offices in the UK Electrical Forum area at ElectriciansForums.net
It looked like the live connection side ( internally) burned against the neutral of the main switch
You'd have to be mindful of SPD conductor lengths doing it that way. I think Matt:E make a single board with Type A RCBO, openPEN detection and...
