SSR relay problem solution
Hello everyone,
I have a goldsmith oven to which I had to change an SSR relay because when it reached 475 degrees centigrade the temperature increase stopped. Since the oven must reach 800 degrees in about two hours, I have to solve the problem.
I changed all the main components to the oven: thermoregulator, thermocouple, resistance. The problem of increasing the temperature was present even before changing all these components.
I ordered an SSR relay of the same brand and model as the one mounted on the oven: Crydom D2425.
Since it was panel mounted I proceeded to modify the panel to put a heatsink in it.
Between the heatsink and the relay I put some Thermalright TFX thermal paste which has a high thermal conductivity power and is also used in computers and can withstand up to 300 degrees.
After having reassembled everything I turned on the oven, this time it reached 100 degrees centigrade after 10-15 minutes the increase in temperature stopped.
I wonder where he went wrong about the SSR relay changing as I think I've done everything possible. Could anyone help me? Thank you in advance for your reply.
I attach some photos to the message.
Please take two photos showing the full details of the rear of the MC101 controller (view A) and of the specification plate (B).
Do you have a record of how you have programmed the MC101?
What is the component just above the MC101 with red coloured connectors?
A strange thing has happened, now when I turn on the oven the red light mounted on the panel near the thermoregulator turns on and the heating starts too, but after about 30 seconds it turns off and the heating also stops working, that light indicates whether the oven is heating or not. The light must remain on throughout the heating process. For example, if the thermoregulator reaches the maximum temperature set, the light and heating switch off and switch on again only when the thermoregulator decides to start heating again to keep the temperature constant. I never paid any attention to whether or not the light came on even when I had problems with increasing the temperature, I would not want the problem to be the same.
Is it possible to start the heating by disconnecting two wires of the thermoregulator and connecting them together in order to exclude the thermoregulator and check if the problem depends on it or on something else? If so, which wires should I connect to each other? I am attaching a photo of the thermoregulator, the wires present are the number 1, 2, 3 and 4.
(The component above the red light is a timer, if the knob is turned and set for example to two hours the heating of the oven will be prevented for two hours, after two hours the heating would restart. To exclude the component I disconnected the wires by connecting them together, I came to the conclusion that it has nothing to do with the problem.)
Greetings from London.
Please post a picture of how the wires have been connected to the terminals on the back of the MC101 controller. The temp sensor uses the terminals I have circled. I am surprised you mentioned terminals 1, 2, 3 and 4 for the temp sensor because the temperature sensor is connected to 8, 9 and 10 dependent on whether it is resistive type or a thermoelectric type.
Please show me a picture of the temp sensor fitted at the moment including any markings. Do you have its details? Do you know whether it is temperature sensor using the change of its resistance (RTD type) to measure temperature or a thermocouple (TC type) which generates a voltage dependent on the temperature? This is important because the controller you have, the MC101-611, has (6) relay and SSR outputs and PID control, (1) upper limit alarm and only operates with a (1) thermocouple. Thus, there should only be connections to terminals 9 and 10 for the thermocouple input. Terminal 8 is not used.
If you have fitted a thermo couple it is important to connect its wires to match the polarity of terminals 9 (-) and 10 (+).
Yes it is connected, I forgot to enter the numbering of the wires here in the forum, however it is connected with the number 9 and 10. The thermocouple are the green wire and the red one. The wires are connected with the right polarity.
Looks like the ssr is connected to the relay output
it should be connected to the ssr output terminals.
however, it May not be as simple as moving them from one set of terminals to another.
you need to look at the instructions for the temperature controller to see the correct way to wire the ssr to the controller
I based on how the previous Eliwell EWTQ905 thermoregulator was connected, the previous thermoregulator had an internal relay which drives an SSR, but the SSR cannot be connected directly to numbers 11 and 12 otherwise the oven does not work and the thermoregulator would go crazy. The oven is designed to be connected in this way.
The temperature controller is designed to drive the ssr direct from its ssr output.
I really think you are going to need someone who has the knowledge to come and fix this for you.
The D2425 requires a direct current control voltage signal. From where is this voltage signal currently obtained which is at the moment routed via the normally open no volt contacts in the controller to the ssr? The D in D2425 indicates direct current control whereas an A as in A2425 would mean alternating current control signal.
There is a Fagor B40 C5000 / 3300 rectifier bridge which has been replaced with a new one just to exclude it from the possible cause of the problem that does not make the oven work.
if You are determined to use the relay output, have you reprogrammed the relay output to be heat instead of an alarm of some type?
The direct current wires come out of the respective polarities of the rectifier bridge and go straight into the input of the SSR relay.
Instead the alternating current wires of which I am attaching the photos are connected to several wires.
As for the alternating current instead (measuring with the tester at the output it says 228 v):
The white wire coming out of the SSR at the top taped together with a black wire goes to the resistance, the black wire instead goes to the panel light which turns on when the heating is in progress. The other wire that comes out of the light arrives in the blue connector present in the power supply of the thermoregulator, they are two wires in the same connector.
The blue wire that starts from the SSR relay ends up in the terminal block next to the rectifier bridge, it is taped together with another wire which goes into the first double connector on the power button at the top, the other part of the double connector goes to the timer and the other wire coming out of the timer goes into the first red power connector on the thermoregulator.
Instead, the last black wire on the right in the terminal board ends up in connector 4 of the thermoregulator.
These are my latest thoughts on why your oven is not working. The D2425 is a 'zero crossing' device. It will only turn on when the mains cycle crosses the zero Volts axis. The condition for it turning is a trigger voltage greater than 3Vdc and a mains voltage less than the maximum allowable voltage for turn on at zero crossing. I show these in my attached diagram.
The trigger voltage is currently derived from the mains 240V cycle via a step down transformer to 24V ish (I cannot remember exact value). The stepped down 24 ac waveform is in synchronism with the mains cycle as I show in the diagram. Thus both the 240V ac waveform and the 24V waveform are in phase and cross over at 0V at the same times. The slope of the 240V ac waveform is greater than the slope of the 24 V ac waveform.
The 24V ac waveform is passed through a full wave rectifier to produce the green waveform . This is a unidirectional voltage but not constant, drops to zero volts and for a short period at crossover is not greater than the minimum 3V dc to trigger the D2425.
I think that the ssr is not triggering reliably. Sometimes the trigger voltage is greater than 3V dc before the mains cycle exceeds the maximum crossover start conduction voltage - the ssr turns on and powers the element.
But at other times (and maybe temperature dependent) the mains cycle exceeds the maximum crossover start conduction voltage before the trigger voltage exceeds 3V dc - so the ssr does not turn on.
The ssr requires a constant unidirectional voltage signal or at least a voltage which switches between 0V and greater than 3 V dc for reliably triggering into conduction. I attempt to show this bottom right.
What to do?
Place an electrolytic high temperature capacitor - say 1000 microFarads 63Vdc electrolytic - across the terminals 3 and 4 of the ssr - ensure polarity of capacitor. Or use the controller's dedicated ssr output which has a voltage waveform suited to signal the D2425 to start conduction at crossover because it instantly exceeds 3V ie: it does not follow the mains cycle waveform.
If you try the capacitor solution buy a few of these:
RS PRO 1000μF Electrolytic Capacitor 63V dc, Through Hole | RS Components - https://uk.rs-online.com/web/p/aluminium-capacitors/7076666
What to do?
In the input of the relay and at the output of the rectifier bridge the measured direct current is 22.6 volts. When the heating process is on, the DC current measured at the SSR input is 22.3-22.4v instead when the heating process is off, it is approximately 22.6-22.8v.
mdkmdk,
ankyzop,
