Static shock from light switches even with power off?? | Page 2 | on ElectriciansForums
Discuss Static shock from light switches even with power off?? in the UK Electrical Forum area at ElectriciansForums.net
C
coxyboy
I was called out to a job today and found something I have never come across before....
when I got to the property the tenant explained what was happening - she was getting what she called a "shock" when ever she turned the lights on upstairs in the two bedrooms and the landing. So I tested to see if there was any voltage at each switch and there wasn't. But sure thing as soon as I touched the switch I got a shock. I would say it was more of a big static shock than a normal voltage shock. So I had a little play around to investigate.
ie removing each switch reterminating and making sure the earths were connected. But still no joy. I turned off the main switch so there was no power to any circuit but I was still getting the static from each switch in both bedrooms and on the landing.
Has any one ever come across this problem before? If so what did you do to solve the problem??
Any help would be much appreciated, thanks
Did a ze test and it was more than adequate, I've just finished rewiring the place, it was only when installing a fitting that we noticed/kept getting shocks. there are a couple of those 28w 2d fittings that I've installed, could it be anything todo with the control ballasts within these? will do a wandering lead test tomorrow, thanks for the advice
Had a lad working for me many years ago that could walk up and down a few times then point his finger near the switch and get a spark to jump across to it told one customer the problem was down to the cheap (ÂŁ4k) carpet he had bought didn't go down well
Isn't that why you don't see many Traffic Wardens directing traffic any more as they could just point a finger at a car and sent 1000s of volts shooting out of the end of their finger towards anyone who abused them?
If you check out the causes of static you will find that you can generate a few K volts just by waving your arms in the air !.
I was changing emg lights in a residential home a few months back . i was getting a healthy sock when pressing the down button on the lift. So I walked about scuffing my shoes on the floor then holding a 8w lamp touched the lift and the lamp lit every time. Made us all chuckle
The most likely explanation is that they are buildig a static charge,
then they touch some thing that is earthed ( metal switch plate )
and thus receive a tingle.
The solution is to change the metal switshs to plastic
so no more earthing thru switch plate.
Or change the carpet !
Reply to Static shock from light switches even with power off?? in the UK Electrical Forum area at ElectriciansForums.net
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
