- Joined
- Sep 13, 2012
- Messages
- 27
- Reaction score
- 4
Is there regulation that says connector blocks can not be used to join cables inside a DB?
Discuss Strip connectors in DBs in the UK Electrical Forum area at ElectriciansForums.net
storm in a tea cup to be honest.
and i've never had any connection problems with the thousands of solid core wires ive crimped , so in absence of any noticable evidence to the contrary , i'll continue.
saying that though , i use indent crimpers rather than compression crimpers which i find to make a better connection.
just because nasa wont do it building a space shuttle doesnt mean its not acceptable for the average joe to extend some t&e in a box..........
Indent crimpers are designed for solid cores these are the correct ones to use i was relating to the ratchet crimpers used on the red/blue/yellow insulated crimps which are designed for fine stranded and stranded cables.
@DPG ... a good point you'll find the crimps we are discussing are not suitable for solid core if you seek manufacturers of either the crimping tool or the crimps unless you are using an indent style crimper.. i dragged this up before with links to the appropriate manufacturers site. Yes agree maybe a storm in a teacup considering the sector of industry most members are in but it does boil down to whether using the available popular insulated crimps is good practice.. i see them fail a lot because i see them on heavily loaded cables which are loaded for long durations (all within design criteria) - a situation rarely seen in domestic hence lack of evidence and issues, but does it mean the practice should be continued because its less likely to give concerns in the domestic sector... again you may never see any issues in this sector but in testing for durability, reliability and functionality the manufacturers of both crimps and crimper under discussion do say not suitable for solid core cables... just because you don't get a instruction sheet or guide when you buy them its often a big reason why its overlooked.
Do remember any joint has to cope with the full S/C current as well and this is something the user will not be able to check without referring to manufacturers guidelines.
Reply to Strip connectors in DBs in the UK Electrical Forum area at ElectriciansForums.net
