Sub-main protection | Page 2 | on ElectriciansForums
Discuss Sub-main protection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The cable is a 25mm 3c so no worries on that front. Personally I'd always fit a switch fuse as has been suggested, however it won't be my decision unfortunately.
Thanks again
So lets go with using the DNO fuse - are you planning an isolator?
Reply to Sub-main protection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
