surface wiring inside container? | on ElectriciansForums
Discuss surface wiring inside container? in the UK Electrical Forum area at ElectriciansForums.net
Ross1
Evening all,
I am pricing a job to run conduit for all accessories within a 20 foot container. the container is not getting internal lining.
As far as I know, containers are single skin. what fixings have you guy used in the past.
thanks
Evening all,
thanks
Secondary support goalpost and brace system made from unistrut. Then you can fix what you want where you want without damaging the container.
Evening all,
thanks
You have to determine the construction by going and looking. “As far as I know” is going to lead to a (expensive) mistake.
You can’t price a job unless you know for certain.
Reply to surface wiring inside container? in the UK Electrical Forum area at ElectriciansForums.net
Thanks Bennie. Yeah I have Oslo microwave sensor 2D type fittings which I was hoping to use. So permanent supply to all this would suffice? Thanks
Ask your electrician when they do a site visit as to what is required they can also notify the installation to Building Control under Part P of...
