View the thread, titled "Suspended ceiling - how do you run lighting calbles ? ? ?" which is posted in Australia on Electricians Forums.
M
mikex79
Hi I need to run cables in a suspended ceiling (grid made of aluminium tees and mineral fiber ceiling tiles, suspention wires are fixed directly to the concret ceiling so there are not wooden beams that I could clip the cables to) the luminaires are already fit so what I need to do is just run the cables. What I have always seen was twin and earth PVC cables laid directly on the ceiling tiles and grid but I just have a feeling that this practice is not right there is something that is telling me that if there is an insulation fault even due to cable rubbing the main beam and tees the whole grid will become live.
My question is if there is any special method of suspending the cables so they will not touch the metal grid od should I clip them directly to the concret ceiling and just drop the cables to the luminaires? do the grid have to be earthed?
all suggestions would be much appreciate
Hi.
Has the job been designed by a company or architect, or is it just private to yourself??
Also are you quoting for the job or do you have the job in the bag??
Hi.
i am just wiring the job, the buiders already fit the luminaires i have to do the wiring. it's a little grocery shop and i need to give a quote. i have to do a separate circuit just for this lighting but it is alright after all this advices i already know what to do, many thanks for everyone that repilied to my thread
Hi.
Do you have a design spec for this job?? It will nearly always be trunking+conduit, and tray work. As has been said the only way to go.
Sorry to disagree with lenny about nearly always being speced as trunking, I have found more architects want Klik boxes for ease of maintenance but on cost effective and budget conscious jobs many are specifying 3-core and earth (fixed correctly of course)(third core fore emer lights). Though saying that it would always be nice to be able to do it in trunking as it is a nice looking job on completion
Interlude i would only use those pad in a controll panel or on the back of a door to hold my jacket up never to hold cables up above a ceiling any heat or humidity and they fall off.
Sparks the Architect will ask tell you the position of lights and type its up to the electrical engineer,spark to work out routes,cable syze,type,containment and then offer a price. Architects have grand ideas and rely on the tradesmen to get it done.
there is a flat plastic clip, looks like a wing with a screw fixing in the middle, and when you screw to ceiling it puts tension on the plastic wing, and you can pull it down then slide your wires behind it.
Hi
Not done any wiring in shops before, but in offices its conduit or trunking with Greg roses above false ceiling tiles I know the budget is not as high for a single shop though. Your installation should be independent for the ceiling installation i.e not clipped or fixed to ceiling supports/ties. Not sure of the term kilk fitting but at a guess are they are the same as Greg roses?. I would use Greg roses for maintainability as you can work on a fitting with turning the circuit off important for continuity of business within the shop. I think someone else has mentioned a small light gauge cable tray and I would fit the Greg roses on the underside, sounds good to me. I would also bond the ceiling grid and the cable tray.
Regards
Reply to the thread, titled "Suspended ceiling - how do you run lighting calbles ? ? ?" which is posted in Australia on Electricians Forums.
