View the thread, titled "Suspended ceiling - how do you run lighting calbles ? ? ?" which is posted in Australia on Electricians Forums.
M
mikex79
Hi I need to run cables in a suspended ceiling (grid made of aluminium tees and mineral fiber ceiling tiles, suspention wires are fixed directly to the concret ceiling so there are not wooden beams that I could clip the cables to) the luminaires are already fit so what I need to do is just run the cables. What I have always seen was twin and earth PVC cables laid directly on the ceiling tiles and grid but I just have a feeling that this practice is not right there is something that is telling me that if there is an insulation fault even due to cable rubbing the main beam and tees the whole grid will become live.
My question is if there is any special method of suspending the cables so they will not touch the metal grid od should I clip them directly to the concret ceiling and just drop the cables to the luminaires? do the grid have to be earthed?
all suggestions would be much appreciate
There was an occasion in belfast where a fault developed on a ceiling grid with cables the ceiling fitter stuck to it.Nothing to do with weight.How can u earth a ceiling gid they are clipped together and give poor continuity.
Trebor the prewired connection come in a veriety of lenghts but a coil of flex and the connections and you can make them whatever lenght you need. When i served my time in first year it was an apprentices job to sit and make them up.
like some1 else said the easiest way is these black plug things (forgot there name) but you just drill a hole knock it in with a hammer and there is an eye for a cable tie to go through electricfix catalogue page 55
Reply to the thread, titled "Suspended ceiling - how do you run lighting calbles ? ? ?" which is posted in Australia on Electricians Forums.
