Swa Banjo?
M
Michael Bloomfield
Hello everyone, having a debate with colleague, concerning SWA connected into metal CU. Can anyone advise the exact reason for the banjo, brass washer with cpc tag, is it compulsory rather than it just looks nice.
Any thoughts sound reasons would be nice also is it a requirement under the regs?
Many thanks for your reply Richard Burns which makes lots of sense, behind the use of a banjo.
Although i wish the locking nuts provided were just a fraction thicker to get a good purchase on when tightening but thats obviously cut backs, i quite often use piranha and flying earth lead, my companion debated that if earth continuity was present with as he said measured to 0.00 ohms on meter is that not sufficient continuity, i gracefully conceded the debate.
So Pete999 - a banjo - fixed to the CU with a nut and bolt and a fly lead?
Could do it that way I prefer a Piranha nut a far better and neater appr
It has the banjo fitted so it must be fine!!!
What on earth did they manage to do to that gland to rip off the end of the clamp nut?
They cut the Armour out of the equation Richard, because they didn't know how to do it properly, you can see from the pics that the Armour was/is /wouldn't reach thecorrect position to form a proper termination.
I don't quite understand this bit. What did your companion actually measure between to get this reading? How accurate is his meter?
I use these when terminating into a plastic box. Great way to maintain earth continuity
When using swa for the ‘tails’ I use 2 core 25mm swa and a 16mm earthing conductor in parallel
So what's the price comparison between the above and 3 core SWA?
I haven't got the charts on me at the mo but isn't the armour on 25mm sufficient for the earth?
Michael Bloomfield,
Pete999,
TrueNAS JBOD Storage Server
