blu-tak
Discuss Switch in brick wall door opening in the DIY Electrical Advice area at ElectriciansForums.net
Make that wireless also. On a 2 gangYes thanks for making me think about that option. I'm starting to lean against because I need to fit a second switch on the same wall but higher up. (I think DP or 3a FCU for a 100W external PIR lamp that is currently hard wired without any isolator into existing 5a lighting circuit) .
That said I could move the location of that somewhere else but there aren't that many options. Maybe the back of the new cupboard but I guess that's frowned upon too.
how would you know? you only just learnt semaphore communication.some can, if you must...
there's a new thing out you can learn. it's called coarse mode... dash it , i meant morse code.I like to keep my eye on new things, Tel...
my good eye, obvo!
Have a look at a couple of online videos on youtube by DSS Electrical will give you a good insight.cheaper alternative . i'm going to order one and see if they're any good. not much outlay for a punt:
Wireless Remote Control Lamp Kinetic Self-powered Wall Light Smart Switch Kit UK | eBay
[ Easily Relocate Light Switch ]- No pulling wires to the switch, no tearing walls, quick remodel existing switches location. [ Switch Can Place Anywhere ]- kinetic wireless switch no wiring needed, mounts wherever you want in the house range, mounting screws and 3M tape provided for easy...www.ebay.co.uk
However, as regards being maintenance free, you don't want to install them in an inaccessible location because you may need to pair the receiver with another switch, or re-pair with the original switch, which requires physical access to the receiver to actuate the pairing button.
Just had a quick look - on the prewired receiver L is Blue and N is BrownI must admit I have been using these a lot recently, they are only in Burton on Trent. Usually come next day as well!
Wireless Remote Control Kinetic Self-powered No Battery Wall Light Smart Switch | eBay
The wireless switch has a built-in micro energy generator. This solves the problem of having to install switch wiring from light fitting to the wall switch. Wireless Smart Lamp Light Switch On/Off Switch Kinetic Self-powered.www.ebay.co.uk
Reply to Switch in brick wall door opening in the DIY Electrical Advice area at ElectriciansForums.net
