Switch in brick wall door opening | Page 4 | on ElectriciansForums
Discuss Switch in brick wall door opening in the DIY Electrical Advice area at ElectriciansForums.net
as he sez....
  • [ElectriciansForums.net] Switch in brick wall door opening
Ahh: Seems like I'm too knew to post links.
You can copy the URL directly into the post
or
If you want to add a link to some text then highlight the text, click the chain pic in the tool bar above - Insert link (Ctrl+K) - and then copy the URL in the URL field.
Ok so I eventually got to the workshop and well all the ones I have are correct so don't know what is going on with the picture!
As I say not had a problem with any of them so far and have installed around 10, some for garden lighting some for a kitchen, all worked flawlessly and they are a lot cheaper than the branded ones[ElectriciansForums.net] Switch in brick wall door opening
Reactions: 123
In my limited experience I have found a few anomalies in wiring labels. I installed 2 thermostats/controllers for heating panels recently. The diagram in the written instruction leaflet,and the diagram printed on the stat, the wiring was correct...but on reading the instructions it reversed polarity...a simple typo really, but if you were reading it out to an apprentice of little brain, things would go wrong.
I brought this to the attention of the distributors, and they said they would "look into it", so that's fine!
Reactions: DPG
Reply to Switch in brick wall door opening in the DIY Electrical Advice area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
