tell me im having a blonde day | on ElectriciansForums
Discuss tell me im having a blonde day in the UK Electrical Forum area at ElectriciansForums.net
G
glasgospark
1 bed flat
smoke alarm install , took neutral from nearest light and live from nearest switch connected smokey switched power on and only light that worked was the one i took neutral from and the smokey worked every other light had no neutral.
puzzled :s
any ideas
when you say you "took" the neutral - could this be a clue?
there was 2 neutrals 1 switch wire at light
1 switch wire 2 loop feeds at switch
connections are perfectly fine , i even disconnected my new cables and the problem still happend
- - - Updated - - -
Well from the very basic info I'd say you've dropped a neutral
yes i did but i cant figure out how :s
Check that the outgoing neutral hasn't broken inside terminal or you clamped down onto insulation. Have you 230v across switch live and neutral at each light
the connections were 2 neutrals at light 1 switch wire
2 loop feeds at switch 1 switch wire
i connected neutral to light and live to loop feed ,
checked every connections dozen times as there was only 2 connections made i was pulling my hair out
Reply to tell me im having a blonde day in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
