tell me im having a blonde day | Page 4 | on ElectriciansForums
Discuss tell me im having a blonde day in the UK Electrical Forum area at ElectriciansForums.net
G
glasgospark
1 bed flat
smoke alarm install , took neutral from nearest light and live from nearest switch connected smokey switched power on and only light that worked was the one i took neutral from and the smokey worked every other light had no neutral.
puzzled :s
any ideas
i already new the problem was a lost neutral , and said at the begining i must have drilled through it but thought it was very coinsidental ,
i have re installed a neutral to the 1st effected point , job done
flat is fully concrete everywhere thus this being easiest fix for now
mft 1720 :D
lol , cant understand it , connected neutral to the looped neutrals at light and took feed from switch perm feed , switched power on and only light that worked was the one i connected to , connections perfectly fine :(
temp fix is done for now though
Dont think the home owners are going to be best pleased having all the concrete demolished inside their home lol
lol exactly , job was a hassle to start with , had the keys for 1 hour only thought no probs will take 20 mins in out cleaned up home time , then this happened so had to quick fix as it was 6pm and there was viewings being done that night
Reply to tell me im having a blonde day in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
