tell me im having a blonde day | Page 5 | on ElectriciansForums
Discuss tell me im having a blonde day in the UK Electrical Forum area at ElectriciansForums.net
G
glasgospark
1 bed flat
smoke alarm install , took neutral from nearest light and live from nearest switch connected smokey switched power on and only light that worked was the one i took neutral from and the smokey worked every other light had no neutral.
puzzled :s
any ideas
Why would that be necessary? The cables are in conduit? Facts are some simple testing would surely locate fault, or at least that's the way I was taught.
Fault that's been solved, he carried or tests at the beginning, now no problems with that, what other faults can a tester find in these circumstances?
So Unless the concrete is demolished to visually inspect the internal sections there can be no more done.
have i got this right , but if the working light is tubed to the second light and u pulled a new neutral to it from the first , then did you not pull the old neutral out and inspect it for damage?
Reply to tell me im having a blonde day in the UK Electrical Forum area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
