View the thread, titled "Tell us about your faults!" which is posted in Australia on Electricians Forums.
K
kung
Hi ALL
Just thought id put this one up for all those faults we find.
heres one to kick it off !
Domestic RCD tripped and wouldnt reset cause was a blown low energy light bulb.:D
There you go now for yours !
Make everything idiot proof and evolution will simply produce a more efficient idiot. There literally is no rest from the insane stuff one comes across. :omg_smile:
Just when you think it's safe.........
Takes me back to the days of the 'chageover period' from 15A (round-pin) to the 13A ring main era. My Dad would bare the ends of flex back and push it in the socket using plastic rawl plugs. Oooppss!
got called over by the old lady down the road about a bulb beeping even when it was switched off,"never liked them fancy twisted things"(energy savers)she says "my old bulbs never beeped and this one has done it from day 1" turned out her battery was going in the smoke alarm next to the light fitting.so i replaced the battery,and the bulb as she wasnt convinced,as she said"well the alarms been in nearly 2 years and never done that before"didnt charge her,dont you just love oap,s they can really make me smile.
Re: Tell us about your faults !
Sounds very much like a disconnected/floating neutral. But this post would be better placed, and answered, in its own thread. This thread is intended for those 'I can't believe what I have just found that some numpty of an installer has done and that I just had to fix' type of faults.
anybody else had anything along these lines of strange voltages ??
Got Called out to a some conduit being hit. How i got a surprise as i thought it might be some conduit had just been a little loose. The idiot had ripped a full DB off the wall and four stop start controllers!!!
Simple one this, and luckily it hadn't caused any problems or injuries. I guess it doesn't "look" like the worst of the worst, but there's absolutely no excuse for it being left like this. The scary thing is that it had just been this way for who-knows-how-long. How many more like this out there?
Story is that I recently started a new job as an engineer, but in the first few days had to keep myself busy so decided to check the electrics in the workshop. There were some mystery breakers on the board so after investigation I'd identified where everything ended up. Scarily, this was found under the workbench, being on the other side of a wall-mounted switch in the 'on' position. The cover was initially in place, so to the untrained eye there would be no need to suspect anything amiss. Basically here was a live cable sitting in metal conduit just waiting for the chance to bite. Lots of people use the workshop for lots of things. Needless to say it's all gone now!
Reply to the thread, titled "Tell us about your faults!" which is posted in Australia on Electricians Forums.
