View the thread, titled "Tell us about your faults!" which is posted in Australia on Electricians Forums.
K
kung
Hi ALL
Just thought id put this one up for all those faults we find.
heres one to kick it off !
Domestic RCD tripped and wouldnt reset cause was a blown low energy light bulb.:D
There you go now for yours !
Another gem
Had to isolate a lighting cct fed from this CU
Looked that bad outside, thought I'd have a look inside, obviously run out of earth sleeving!
Meticulous labelling. Makes it so easy to find the circuit you need. (actually two are labelled (wrong way round), in felt-tip, bottom right)
Do those feeder cables/tails have any protection through the DB caseing ?? I can't quite make out too well if those coloured cables are going through separate holes or a slot entry, either way it doesn't look like any protection has been afforded here either!! lol!!
SWA for outside lights 'buried' about two inches below the ground, and under a tarmac driveway, where at least it is sleeved in water pipe! And yes, that is the armouring you can see. :D
Reply to the thread, titled "Tell us about your faults!" which is posted in Australia on Electricians Forums.
